Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Did I Kill My Opus?
  1. #11
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Actually mine flashes once every 4 seconds, that just means the opus is getting power and is waiting for the ACC signal
    肚子笑痛了
    S60 Install
  2. #12
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    So this isn't entirely accurate?
    1 Flash:
    Battery voltage is below normal operating range.
    The normal range is 11.5 VDC to 18 VDC.
    During engine cranking the low battery voltage detection is ignored so the
    battery voltage can dip below 11.5V.
    I need a manual, anyone have a link? The link in the mp3car store doesn't work.
    Chris.
  3. #13
    May 2003
    Miami, FL
    http://65.33.203.206:118/serve/Opus%...r%20Manual.pdf
    but see it just says one flash, thats it.
    if your getting a repeating single flash that just means it's in standby waiting for you. Thats what mine does, just a single flash every 3 or so seconds, just tells me it's getting power and waiting for the ign to be turned on.
    肚子笑痛了
    S60 Install
  4. #14
    Nov 2003
    Massachusetts
    So the ignition line could be bad? Will the Opus not operate without it? I wonder if the fuse that runs through could have blown... hmm...
    Thanks again.
  5. #15
    Jaz
    Jaz is offline
    Apr 2005
    have you got the green and white wire going to the motherboard plugged in? although on most pc settups it doesnt matter what way it is on the motherboard, on the opus it does matter.
    and no the Opus will not operate without an ingition line, this is what activates the opus to turn on.
    put a multimeter on the ignition line while you turn the key. it should go from nothing, to your normal car voltage.
    Then make sure your green and white cable is the right way round on your motherboard.
  6. #16
    May 2003
    Miami, FL
    Quote Originally Posted by ukchris
    Thanks again.
    Yeah, what I would do is try shorting the acc wire on the opus to 12v, see if it tries to start. If the green/white wire is backwards you will get a double flash. At least that way you know for sure it's the opus and not something else
    肚子笑痛了
    S60 Install
  7. #17
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    the Opus does not get the "hey wake up" signal without a functioning ignition line. Its best to check the voltage at the Opus. Just put your multimeter across the iginition line and the ground with the car on.
  8. #18
    Nov 2003
    Massachusetts
    Woo hoo! It's working!!
    It wasn't a fuse, but was the ignition line. My car has a "phone connector" plug which I am using to power the screen, the FM modulator, Valentine 1 and the Opus ignition line. I have a 9 pin molex connector on it to give me the 4 grounds, 4 ignition and 1 live that I need. Seems the connection was loose, a bit of a prod and everything came back to life!
    My only frustration... I have to install the Epia MB drivers to get sound working before I can test the sound through the PC, but it's all progress!
    Thanks to all of you for your help and suggestions.
    Chris.
  9. #19
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    nix that...
    BossTone74
  1. HOLY CRAP.....this is insane
    By cadence117 in forum Off Topic
    Last Post: 06-17-2008, 07:37 PM
  2. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  3. opus for dummies guide?
    By sanbas in forum Power Supplies
    Last Post: 03-21-2005, 07:56 PM
  4. Opus kill switch
    By naveedh in forum Power Supplies
    Last Post: 12-23-2004, 09:19 PM
  5. Replies: 8
    Last Post: 06-05-2004, 11:13 AM
