Results 1 to 6 of 6
Thread: M1-ATX sufficient enough for this setup?
    Constant Bitrate Power_nisse's Avatar
    May 2004
    Sweden
    Cool M1-ATX sufficient enough for this setup?
    I will connect following
    VIA EPIA SP13000, m/Via C3 CPU 1300MHz Mini-ITX,DDR400,VGA,Tv-Out, Firewire
    Crucial PC2100 DDR-DIMM 512MB CL2.5. Non-parity, 2.5V, 64Meg x 64
    SATA - Samsung SpinPoint M40S 80GB 5400RPM SATA2 2,5" 9,5mm
    IDE – Slimline Panasonic DVD ROM/Cd RW 4x
    USB - A 7 Avator 7 tft Touchscreen, screen and usb connected
    USB - 3COM OFFICECONNECT 11G 108MBPS WIRELESS WLAN
    USB - GPS, The gps has batteri but recharges via usb.
    USB - Remote controll later on
    USB LCD from http://www.crystalfontz.com
    According to power calculators its on the edge of wattage.
    "maybe" need the "opus 120
    solution
    Maybe a OPUS 120 will do it! Just have all components in the ampie case and install the OPUS beneath it in a box. Drill holes for the wires etc
    Ill go for that solution =) IF the M1 isn`t Sufficient enough.
    What do you think?!? =)
    Constant Bitrate Jeep's Avatar
    May 2004
    Sweden
    I run this on a M1-ATX
    EPAI M1000
    3.5 HD
    USB wifi
    USB bluetooth
    USB > Serial adapter
    USB Hub
    USB GPS
    USB tira (remote ir eye)
    Terratech TV600 PCI card
    and power to my Lilipt 7" screen + 12v fan
    No problem at all.
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    aboput the same stuff as my setup and it works ok.
    May 2004
    Sweden
    Thumbs up
    Wow a 3.5 HD is that on 7200 RPM or 5400.
    And a Terratech TV600 PCI card hehe you sure do pushing it
    ok so i guess its ok then hehe
    Thanks so much here is the reward -->
    May 2005
    Estonia
    M1-ATX is enough, i run more power needing system without any circumstances
    _
    Mar 2004
    Little Elm, Texas
    I'm currently running the following on my M1:
    MII12000
    3.5" 200 GB hd
    Panasonic slim-slot DVD
    512 MB PC2100 ram
    PCMCIA Audigy ZS 2 sound card
    and am using only one of the USB ports. The other one has a USB hub with is powered.
    No problems here.
    I am looking at switching to the SP13000 as well though, going SATA, 1 GB of PC3200 and utilizing all 8 onboard USB options....not sure if i'll be pushing the M1 then or not...lol
    Jan Bennett
  1. M1 ATX problems
    By Tompa B in forum Power Supplies
    Last Post: 09-25-2005, 07:39 AM
  2. m1 atx 90watt...is it for me?
    By psycos in forum Power Supplies
    Last Post: 08-13-2005, 12:06 PM
  3. M1-ATX sufficient enough for this setup?
    By Power_nisse in forum LCD/Display
    Last Post: 07-28-2005, 07:51 AM
  4. Whats happens -> M1 ATX combined power overloaded?
    By Me&you in forum Power Supplies
    Last Post: 05-09-2005, 04:28 PM
  5. Replies: 15
    Last Post: 06-24-2004, 10:49 AM
