Results 1 to 10 of 14
Thread: Quick question about the ITPS
    May 2005
    Vienna, VA
    Can I hook up the white wire (unswitched) to the same source as the red wire (switched)?
    I'm planning to the ITPS (coupled with a laptop DC-DC car adapter) to power my laptop and my Xenarc screen. I mainly use the ITPS as a cheapass regulator and nothing else. Would this work?
    FLAC shakes's Avatar
    Oct 2003
    Atlanta GA
    yes, you just need to make sure your source can supply enough current to power whatever you're powering with the itps.
    you'll also need around 13.5v to get 12v out on the itps.
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    i'm planning on doing this too. i think i'll in the end have 3 PSU in my car, my OPUS in the back, my ITPS in the front (for my lilliput), and a carnetix 5v to power my USB hub and other USB devices (slot dvdrw). Havent seen a lot of info on people doing this.
    edit: (slow dvdrw) should be (slot dvdrw)
    PC Components:
    My work log
    May 2005
    Vienna, VA
    shakes, thanks.
    Just to make sure. The unswitched white wire is just for the ITPS to continue to provide power for the computer to shutdown properly after ignition is off, correct?
    I don't use this feature so I thought hooking up the white wire and the red wire to the same outlet (my cigarette lighter) would be fine.
    Oct 2003
    Atlanta GA
    Quote Originally Posted by Peoples
    i'm planning on doing this too. i think i'll in the end have 3 PSU in my car, my OPUS in the back, my ITPS in the front (for my lilliput), and a carnetix 5v to power my USB hub and other USB devices (slow dvdrw). Havent seen a lot of info on people doing this.
    wow ... talk about overkill. I could see adding the ITPS so you don't have to run another line all the way up front ... but mak a Carnetix is an expensive 5v regulator.
    Quote Originally Posted by b8bboi
    shakes, thanks.
    I forget the colors, but in a normal application, the switched (IGN) wire on the itps just acts as an 'on off' switch and requires little current. When turned on, the ITPS takes the power from the main power line. So by hooking these together you're essentially making the ITPS draw all it's needed current from the same power source that tells it to turn on and off.
    usually this is a bad thing because a typical car's IGN line isn't rated for very high currents.
    if you're just going to power your LCD and you're using your cig lighter, it should be fine.
    My JeepPC Install
    Nov 2003
    Marietta, GA
    I think he's talking about the P5V (~$25) for +5V USB devices.
    MikeH
    May 2005
    Vienna, VA
    shakes, you were right.
    The ITPS is officially a piece of ****. It only provides 11.75v and during cranking, it dips down to 10+v. My Xenarc requires at least 11V.
    Lucky for me I got the ITPS for free from a friend. I don't know how it even got on the market. ******* piece of crap.
    Oct 2003
    Atlanta GA
    what voltage does your dc-dc laptop power adapter output?
    My JeepPC Install
    Dec 2004
    Maryland
    Quote Originally Posted by MikeH
    yep
    PC Components:
    My work log
    May 2005
    Vienna, VA
    Quote Originally Posted by shakes
    It's 19v. I was intending to let the ITPS regulate the 12V from the car and pass that to the laptop adapter but since it won't provide enough voltage, I'll probably hook the laptop adapter directly to the car outlet. The outlet actually says that it can handle up to 120W, which is more than enough for the laptop.
    This is safe (for both the car and the laptop), right?
  1. Quick grounding question
    By GingerPrince in forum Power Supplies
    Last Post: 11-06-2004, 09:28 PM
  2. ITPS confusion question
    By Sonicxtacy02 in forum Power Supplies
    Last Post: 10-20-2004, 11:58 AM
  3. ITPS Ground Question
    By tbird2340 in forum Power Supplies
    Last Post: 09-07-2004, 07:57 AM
  4. Quick question about multi-channel amps
    By imprezive one in forum Car Audio
    Last Post: 08-06-2004, 02:23 AM
  5. quick question
    By septicdeath in forum Power Supplies
    Last Post: 06-30-2004, 11:57 AM
