after almost 3 years of "planning", I'm finally putting everything together
here's my current setup:
Car Battery -> ITPS -> PW200M -> M10000
LCD screen shares the 12V power output from ITPS.
when everything is connected, (harddrive, pci wifi card, lcd connected to the motherboard), and ITPS is powered by a 4A, 12V power source, the motherboard won't boot at all. the CPU fan spins for a split second and stops.
then I took the harddrive and wifi card off, switched to a more powerful power source (13.8V, 30A). this time the motherboard will boot, but then kept rebooting itself...
I did some metering, voltage coming out of ITPS is 11.96V, but out of PW200M's 12V is only 9.2~9.3V. I'm guessing that's the reason for constent rebooting... (the motherboard tested ok with regular ATX power supply)
if I skip ITPS, the computer works fine, but I really need the automatic on/off switch feather, ITPS won't work with proper load, what should I do now? other than buying another power supply...
thanks in advance for all the help!
Project:Carputer
[====================] 100% Completed, done, finished!
Car: 2003 VW GOL
Motherboard: VIA M10000
PSU: ITPS + 12VDCATX + 7.4ah 12V battery
Monitor: 7' LCD with Video, S-video, and VGA
GPS: deluo USB
