Hi all, i´m new here. I want to open the trunk with the 2nd channel of the car alarm. The alarm is a Prestige APS-25CH. The instalation manual says this:
DARK BLUE WIRE: 300 mA PULSED OUTPUT/CHANNEL 2
The dark blue wire pulses to ground via an independent RF channel from the keychain transmitter. This is a
transistorized, low current output, and should only be used to drive an external relay coil.
WARNING: Connecting the dark blue wire to the high current switched output of trunk release circuits
or some remote starter trigger inputs, will damage the control module.
Connect the dark blue wire to terminal 86 of the AS-9256 relay (or equivalent 30 A automotive relay) and wire
the remaining relay contacts to perform the selected function of channel 2.
I already have the relay. The thing is that i don´t know what to connect to the other terminals.
and what is the 87a for?
87a is a normally closed (NC) terminal. It's a switch that is normally closed when no power is applied to the coil (when you are not pressing the button on your remote)
Epia MII 10000 512MB RAM - 60 GB 2.5" Hard Drive -Opus 90 - Lilliput 7" Touchscreen - Panasonic 8123 Slotload DVD burner - PCMCIA USB2.0 Card - Rikaline 6010 GPS - PS2 Micro Keyboard
oh yeah, also check that your trunk release is a pulse high or a pulse low to find you if 30 should be connected to ground or to the +12 signal (On mine, it should be connected to ground). Try this test, if you touch the trunk release wire to a nice ground point, did your trunk open? if not, try a better ground (to make sure) or a +12 signal.
