I own a M1-ATX, and the component labeled Q2 keeps burning up. Can you
> tell
> me what this component does so that I can trouble shoot it. Also if you
> could send me a few of these components so that I can solder them on where
> the burnt up Q2 is. I will be willing to pay shipping and for the price of
> the Q2 components. Please send me a quote.
> -Drew
> 513-319-3100
> m1-atx ordered from
mp3car.com <http://mp3car.com>
Q2 is a PMOS rated at 5A, FDS9453A. You are taking too much power from the
12V rail!
You could use a more powerful FET, FDS6679Z, but you will burn other things,
I think.
Try to reduce the 12V rail power consumption and you will be OK!
-Andrei
So was I overloading the 90 Watt maximum that the PSU could handle? I have a 7200 Rpm HD (30.9W) , A 733 MHz Celeron (22.8 W), Motherboard (12.35 W), TouchScreen (2.5W), LCD (7 W), Keyboard (.25W), and 2mb videocard ( 4.15 W). This seems to be around 85 Watts, Wouldn't the PSU cut out instead of burn up. Do you think I wired something wrong? When you say "try to reduce the 12V rail power consumption it sounds like i might just be overloading the PSU.
Thank you for your help
drew
The total powert consumption is less important than consumption on each rail. Looks like your 7200RM, LCD and
video card consume from the 12V rail.
The offenders seem to be the 3.5" HDD and LCD. Hard drives consume a lot of power from the 12V rail at spinnup!
-Andrei
Can I purchase a few Spare PMOS, so that I can solder one in place of my burnt one? I will see if i can take some components off of the 12V rail. Is it possible to use 2 M1-ATX, and use one for my HDD and a few small things, and the other for my Processor and mobo and a few
onboard components?
Thank you
- Show quoted text -
Drew
Drew,
Please go to
www.mouser.com and find the parts, they are really cheap.
As far as hooking up 2 M1-ATX in
parallel, I would strongly suggest against doing that. -- this is a microprocessor controlled unit, you have 2 brains working at the same task, not a good idea.
-Andrei
This is the last email I swear, Thank you so much for all your help though. When you said FDS9453A, did you mean FDS9435A, because this is the only thing that I found that came close to that part number?
http://www.mouser.com/index.cfm?hand..._pcodeid=51229
Is that the part that I need?
It is FDS9435A, sorry.
http://www.fairchildsemi.com/pf/FD/FDS9435A.html
