Results 1 to 6 of 6
Thread: Looking for 6V 4.5 amp PSU
    Constant Bitrate JPuma's Avatar
    Jul 2005
    NY
    Hi all,
    I added a Belkin 7 port USB in my car and it requires 6v at 4.5 amps. I tried a 5V 7amp and it powers the USB but the computer cannot recognize some devices that are connected. I was thinking if I could step up the voltage on the 5v but I am not sure exactly how to do this.
    If some knows of a nice 12V input PSU that outputs 6V at 4.5-5amps please tell me. I want to use this belkin USB since its working well with all my hardware that needs ample power from the usb hub.
    open your 5v/7A PSU and take photos of inside, I will show you how to fix it into 6V.
    Constant Bitrate SinnerG's Avatar
    May 2003
    Long Beach
    I have the same hub, but I don't think I can make a PSU with 4A. I believe the AC PSU is nothing more than a filtered step-down transformer. I, myself would like a DC PSU with the specs of the AC PSU.
    Low Bitrate marshallh's Avatar
    Apr 2005
    Kansas
    It looks like the LM338T may work for you. It will dissipate tons of heat as its a linear regulator, but since its regulating 6v then it should have no problems working during a crank. Here is the datasheet
    http://www.national.com/pf/LM/LM338.html
    Progress:
    [■■■■■■■■] 100%
    Mitsubishi 3000GT car computer
    Previous budget Honda carputer
    Jul 2005
    NY
    okay. currently I am using this
    PST-ITX-1 Mini ITX power board
    http://www.powerstream.com/dc-3318.htm
    I found this a while back and it was a great solution to power up a 5V 3amp DVD/CD-RW slot load I have embedded in my armrest console. Looks really sweet btw. I also have a ITPS before it to regulate its 12volt unput. So with the DVD needing about 3 amps then I have 4amps to play with. I dont thing the USB hub needs a whole 4amps, thats probably just max for the load it can handle. So show me what I can do with this power supply to get 6v off the 5V line. Mind you this also has 12V that I am not using at all. Not sure if stepping it down to 6V will raise the 2amp to 4amp being that your dividing the voltage. Also, I was curious if the other 5V outputs on this PSU are all tied together, if not I could use another 5V output if its not a good idea to use the USB hub and the DVD player off the same 5V 7amp line.
    Thanks to those who responded.
    Oh, btw, I just picked up a P1900 for my moca 7043 pc and I am using the CarPC Pro v.2.4 to control the pc and psu along with a tank module and battery. Man, where was this stuff a year ago
    Joe
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    Quote Originally Posted by JPuma
    Joe
    Hey man, just wondering if you're using the sleep mode on the p1900??
    I'm using the P1900 w/ a Commell 671, I set the JP1 pins 5-6 jumpered, and after about a couple of minutes the unit turns off hard...
    I've run out of ideas and I'm not sure why it's refusing to cooperate.
    Thanks...
    08 Lincoln Navigator www.mobiteklink.com
  1. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
  2. Amp Remote Turn-on via PSU?
    By bulgogi777 in forum Car Audio
    Last Post: 08-24-2004, 11:58 PM
  3. LCD, PSU, placement of carputer?
    By egeekial in forum Newbie
    Last Post: 07-29-2004, 06:08 PM
  4. Replies: 1
    Last Post: 11-17-2003, 04:21 PM
  5. mircoATX PSU?
    By ODYSSEY in forum General Hardware Discussion
    Last Post: 03-12-2001, 03:30 AM
