Results 1 to 9 of 9
Thread: Carnetix 1260 LED WONT TURN OFF!
    Apr 2005
    When I go to test the battery power it blinks the 2.1 times then it stays on. It says it should stay off in the manual but doesn't say why it would stay on can someone help?
    Apr 2005
    also anyone know any good sites with wiring diagrams of cars? I have no idea where the ignition wire is in my car.
    Apr 2005
    Hello anyone out there with a 1260 know the answer? I found the ignition wire but its not putting out enough wire. I saw someone talk about using a wire behind the fuse box to make theirs work but I have no idea what wire that is.
    Oct 2004
    Massachusetts
    what do you mean "it's not pulling out enough wire?"
    If you mean that the ignition wire is not long enough to reach your 1260, just use a length of wire bought from anywhere (about the same size as the one on your 1260) to make it reach.
    P.S. it doesn't have to be the ignition wire, it can be any wire that goes from 0 to +12-14 volts when you turn your car on. Most people tap into their cigarette lighter or Accessory wire since they are usually switched with the ignition. Get your voltmeter and start hunting!
    Epia MII 10000 512MB RAM - 60 GB 2.5" Hard Drive -Opus 90 - Lilliput 7" Touchscreen - Panasonic 8123 Slotload DVD burner - PCMCIA USB2.0 Card - Rikaline 6010 GPS - PS2 Micro Keyboard
    Apr 2005
    Quote Originally Posted by shamyday
    AWESOME! I didn't mean enough wire I meant enough power. I am going to go try and tap the cig lighter right now
    Apr 2005
    cig lighter didn't work the thing with the 1260 is it is supposed to blink 2 times then 1 then 1 to signify 2.1 then the light is supposed to turn off. The light stays on and it does this when the ignition wire is not getting enough power. I have a multimeter which I have no idea how to use even after readon the instructions but meh I am a SUPER noob at this stuff its probably easily to you guys.
    Oct 2004
    Massachusetts
    the whole thing sounds pretty strange. Test it out at the battery, to make sure that you are getting maximum voltages. Wire your + and - wires directly to the battery, then see if touching the Carnetix ignition wire to the + of the battery gives you the behavior you expect. It just isn't going to get better than that for maximum power.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Yeah, hook up the Carnetix directly to the battery and see what you get. Hook the + to + and - to -, of course. Then touch the wire that is supposed to sense the ignition to the + terminal to simulate the key being turned on.
    The multimeter hooks the + lead to the + 12v terminal and - lead to the - terminal of the battery, (of course). Make sure the meter is set to measure volts. You may have to set the range on it to get a proper reading. Ultimately, you should get a readout of something like 12.2 volts or thereabouts. Once you have it set properly, you can go searching about your car for an ignition wire by grounding the - lead and trying different wires with the + lead. You'll get a voltage readout when you've got the right wire.
    Also, post up on the Carnetix forum if you think the 1260 is defective. They can help.
    Want to:
    Apr 2005
    ARGH!!!!11!!!!11!1
    the damn thing works.....I just forgot to ground it. When I saw Macmini's post it clicked
    I have been working on this since 11:30 and all it was was the damn ground!!!!!!
  1. CarPC w/ Carnetix 1260 windows shutting down...?
    By Urinemachine in forum General Hardware Discussion
    Last Post: 07-03-2005, 08:51 AM
  2. Carnetix 1260 driving me nuts
    By Gobby in forum Power Supplies
    Last Post: 06-16-2005, 04:46 AM
  3. Carnetix 1260
    By residentalien in forum Classified Archive
    Last Post: 04-13-2005, 08:20 PM
  4. Carnetix 1260 for my carpc?
    By rustyboxx in forum Power Supplies
    Last Post: 03-05-2005, 02:55 AM
  5. Carnetix PSU 1260 60W - UK purchasers
    By Pabs in forum Power Supplies
    Last Post: 10-02-2004, 08:52 AM
