Results 1 to 3 of 3
Thread: Best way to power a lacie d2?
    Newbie davebateman's Avatar
    Apr 2005
    Manchester, UK
    the problem ive got is that im running my system off a laptop which obviously restricts me in file sizes.
    ive only really got one option and thats to plug a lacie in via firewire (im looking around 250GB)
    now ive already got a d2 250gb for my desktop, the psu says:
    DC output
    5v 2.0A 10W
    12v 2.2A 26.4W
    how would you guys power this in a car?
    would you use an inverter? i was thinking i could get a cheap 12v mini itx psu and run a hard disc off that but its cheaper to get the inverter.
    the rest of the system is gonna be running off a 2nd battery
    so basically what would you do if you needed more storage on a laptop but it has to be a 3.5" drive?
    cheers!
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Why does it have to be a 3.5" drive, exactly?
    I'm using an ADSTech external 2.5" enclosure that runs firewire on my CarPC. It's currently hooked up and powered through the 6-pin firewire plug on my CarPC.
    It works with a laptop too, and comes with a 6-pin to 4-pin wire to plug into the laptop, plus it powers the drive off a USB port. I think the case is (was, at least) around $100. Then just get any notebook drive you want. I know BestBuy sells a Seagate 100Gb for $200.
    Or just find portable harddrives that run off USB..
    Apr 2005
    Manchester, UK
    it has to be 3.5 because i need high capacity at low cost.
    it cant be usb as i have 7 usb devices already.
    it has to be 4 pin firewire as thats all i have.
    its deffo gonna be a 3.5, im just trying to figure out how best to power it.
    its looking like im gonna have to get a psu and power the drive off that. i also need to power a dvd rom in the dash so it would make sense to power them together.
    hmmmmmm
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. N00b Power Question
    By jamiewhittingha in forum Power Supplies
    Last Post: 03-25-2005, 01:08 AM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
  5. HELP!! Power Supply wont supply power
    By Saab in forum General Hardware Discussion
    Last Post: 08-28-2000, 10:33 AM
