Results 1 to 10 of 13
Thread: Battery keeps dying !!!
    Nov 2004
    Angry Battery keeps dying !!!
    Hey,
    Well here is my problem. I have my shuttle powered through my Xantrex 300w inverter. It has been working fine for about 2 or 3months without any problems. I also have my Xenarc powered through the same inverter so it is powered through the standard wall outlet plug also. I have a power switch wired to my dash. When i leave the car, i turn off the Comp with the switch and the xenarc then auto-offs. lately (for about 2-3 weeks), i have had the battery dying on me a few times when i leave it overnight. I always have the inverter on but the comp is always turned off when i leave the car. I have checked my connections to the inverter and everything is fine. The only thing i have noticed is that before, the Xenarc would display "power off" then turn off by itself, now, it does that about half of the time. It still looks like it turns off, but it just doesnt display power off. Could that be the problem? if so how do i fix it and if not, what could it be? Thanks.
    Newbie etown's Avatar
    Jun 2005
    Shilo MB, Canada
    It could be something as simple as a dying battery. I'm guessing that you drive a Mazda3 so your battery isin't old.
    My next question would be what are you running for audio? Is it stock? If not you could be overloading your alternator and not charging the battery enough when you drive. I'd hook up a volt meter to the car and drive around a bit to see what's going on.
    I'd also get rid of the inverter and get a proper 12V power supply. 12Vdc -> 120Vac -> 12Vdc never made sense to me.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mazda3uzr
    I always have the inverter on .
    Turn the 'king thing off.
    Low Bitrate Coldfusionpower's Avatar
    May 2005
    Malaysia , Asia
    i also have the same problem with my previous setup . it's turn out that the relay controlling the inverter is NUT ! it keep "on position" even after i turn off the ignition key .. check ur inverter wiring . maybe the wire is touching other wire ??
    First 3 Version DONE ...but sold ..with the car .. now .. building another one for the new car .
    Coming Soon : CarPC 2.0 .. 40%
    Variable Bitrate numbers's Avatar
    May 2005
    Quote Originally Posted by Enforcer
    Jul 2005
    Malaysia
    I'm using an inverter too and it sucked my battery even when I had everything else turned off. The inverter will continue to draw power as long as it is on.
    I placed a switch between the battery and my inverter, so that allows me to disconnect the inverter from the power source when not in use. Haven't had any battery drains since.
    Jul 2004
    You could set up a second battery and a battery isolator to split the charge between the two batteries. That's my set up right now. The isolator gives the cranking battery priority and then charges my 2nd battery.
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    lmfao, you gotta turn the inverter off.
    2000 Sunfire build 100%, or is it ever really 100%?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    And somebody posted a question about why people are willing to pay for an Opus...
    Want to:
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Did anyone say to turn off the inverter yet?
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 12:45 PM
  2. stinger sp800 battery keeps dying
    By therussman2002 in forum Car Audio
    Last Post: 02-17-2005, 02:12 PM
  3. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  4. time to a dead car battery?
    By chuckctv in forum Newbie
    Last Post: 08-24-2004, 03:47 PM
  5. time to a dead car battery?
    Last Post: 08-20-2004, 11:08 PM
