Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Carputer stalls when accelerate the car
  1. #11
    Variable Bitrate wallaceacura's Avatar
    May 2005
    SE Wisconsin
    Quote Originally Posted by kbyrd
    C'mon now, really? What do normal street cars pull when accelerating? It can't be more than 1G, probably something like 0.5G to 0.75G max. If this is his problem, he can generate more force by braking.
    Even a Porsche 911 has a tough time getting 1g on the skidpad. And that's under optimal conditions
    Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
  2. #12
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    Quote Originally Posted by wallaceacura
    Actually I just re-read what I wrote and it makes no sense that brake would generate more force. The tires are the limiting factor, not the engine versus the brakes stopping power.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
  3. #13
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    True but if Drives do not skip during a car crash why would aggressive driving at a start/stop matter.
    They work right through the car crash... I have done it.
    The issue will be a loose connection or power related.
    TruckinMP3
    Read the FAQ!
  4. #14
    Constant Bitrate Gibson99's Avatar
    Aug 2004
    Houston, TX, USA
    it's true though, that almost every vehicle on the planet can stop MUCH faster than it can accelerate, so braking G force will be much more than acceleration G force, and is usually applied MUCH more abruptly. top fuel dragsters excluded.
    a porsche having a hard time hitting over a G on the skidpad? well, first off, to get up to and maintain that 1g you can't be abrupt about anything. abrupt G forces is what causes hardware failure, not smoothly applied ones. and if my miata can hit a lateral G on street tires, then a porsche should be getting at least 1.25 lateral Gs. unless it's like a 1958 porsche... heh
    back on topic, i think he's definitely looking at a loose connection somewhere. and yes, it's entirely possible for low-grade power transients to cause a machine to stutter but recover once the transient is gone. i used to see it surprisingly often at a former job. once we installed UPSs with power filters, the stuttering went away completely. all depends on the machine itself. some hardware can tolerate it better than others.
    Previous: CamryAmp 1.0 - 95 Camry SE V6 Coupe (sold)
    Current: CamryAmp 2.0 - 98 Camry CE V6 5spd (still bench-testing)
  5. #15
    Variable Bitrate 12Vsystems's Avatar
    Mar 2005
    Orange County, CA
    I don't think it's the G force that causes the problem.
    I am having the same issue on my motorcycle computer. When ever I hit the gas the MII 1000 sometimes reboots or the music just skips a bit.
    I hooked up a volt meter and found that when I hit the gas my battery is getting 13.1 volts but for some reason every once and a while the volt meter drops down to 0 volts. Which is what I think causes the skipping/reboots.
    Could this be a bad engine ground?
  6. #16
    Aug 2005
    Near Buffalo, NY
    The cars increased engine speed might be causeing some emi. My buddy has a problem that whel his car accelerates his alternators or something puts out interference and he had a portable cd player in his car that would stutter or restart the track. Just a tought, i dont know where exactly your computer is in your car but that could be a contributing factor.
  7. #17
    Jan 2004
    Jersey/NY
    why don't you just put it in neutral, rev the engine.... no acceleration, and you get the spikes in voltage
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  2. My carputer broke my car...
    By dgilman in forum General Hardware Discussion
    Last Post: 07-01-2005, 03:47 PM
  3. Project Car needed some gearheads on Carputer
    By FastAttack in forum Newbie
    Last Post: 11-04-2004, 01:33 AM
  4. Real Time Car tracking now working!
    By Magpie in forum GPS
    Last Post: 10-27-2004, 05:08 AM
  5. First my carputer crashed... Now my car crashed!
    By dos4who? in forum Off Topic
    Last Post: 11-28-2001, 09:22 AM
