Page 12 of 18 FirstFirst ... 23456789101112131415161718 LastLast
Results 111 to 120 of 177
Thread: 300W tiny PSU final feature requests collecting
  1. #111
    Sep 2005
    Thumbs up At the final
    Which is the final price for the power supply???
    and when is the beguinne the sale
  2. #112
    Sep 2005
    When one is going away to begin to produce and when its sale?
  3. #113
  4. #114
    FLAC evandude's Avatar
    Mar 2005
    Maine
    I'm not entirely sure where dragon is with the PSU itself... we've got a more concrete set of functions and I/O that the SDC board needs to have so I can throw the design together... I'm quite anxious for a prototype PSU to be ready so I can set up and test out the SDC design, and I'm just as anxious as I'm sure you all are to see how great i'm sure the power stages will perform... from the various single-stage output currents dragon has tested and mentioned in this thread and elsewhere, I'm pretty optimistic about it.
    once again, we can't really estimate the price until a somewhat final prototype is together, and we can find out component and manufacturing costs.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  5. #115
    Slovenia (EU)
    Hi, you guys are doing great PSU. I will defenetly try to buy (at least) one when(if ) it is relesed. Just an idea: would it be possible if anything in PC or PSU becomes too hot (or cold), that PSU would turn off everything? So we wouldn't need to worry abou high (and low) temperatures.
    PS: If it is not done jet I wote for vented verion.
  6. #116
    Mar 2005
    Maine
    Quote Originally Posted by stric
    we are incorporating a temperature sensor, which will be monitored by the SDC.
    over-temperature alarm and emergency shutdown are things we're already planning on, hadn't thought of monitoring for under-temp, however I can see how it could come in handy on those really cold mornings in some places... and it would only be a little bit of extra code so it shouldn't be a problem.
    eegeek.net
  7. #117
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I would like an update from dragron aswell
    I have the opus 150w and had to buy the Opus 80w for an auxiliary power supply because i was overloading both rails.
    I would like a simpler solution with better shutdown options. I should be set for the time being but i am following your progress closely and await further news.
    Cheers
  8. #118
    Jul 2004
    Quote Originally Posted by evandude
    Why would those of us in cold climates want the system to shut down on very cold temperatures? That would mean that I wouldn't be able to use the PSU for 6 months of the year!
    If the idea is to shut the system off to save the hard drive in very cold temperatures, keep in mind many of us in cold temperatures don't use a hard drive - I use Compact Flash to avoid freezing. I vote NO on a cold temperature shutdown...
  9. #119
    Aug 2005
    the Netherlands
    You also have condensation of water at lower temperatures in the car. It could be a problem.
  10. #120
    Registered User
    May 2003
    Quote Originally Posted by Jackboot
    Low temp warning or "dont power up on low temp" option is more appropriate.
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  3. Does a 300w PSU need a 300w inverter?
    By Max018 in forum Power Supplies
    Last Post: 03-24-2004, 12:53 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
