Page 2 of 18 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 177
Thread: 300W tiny PSU final feature requests collecting
  1. #11
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by evandude
    Meddler, I'm doing the programmable SDC for this thing, so PM your ideas to me
    Or, for that matter, post them here, as this is a feature request thread
    Ability to control a few relays after computer has turned on. So delay for screen and amp.
  2. #12
    FLAC evandude's Avatar
    Mar 2005
    Maine
    The plan is to have the SDC expandable.
    due to the apparent size constraints on the SDC board, there's barely room for an 18-pin PIC, so the number of onboard I/O is limited. Thus far, onboard, in addition to the typical connections for power control, I have placed a temp sensor, some status LEDs, serial lines, and analog voltage measurement to monitor the input voltage. This board will have any settings (like all the delays, thresholds for voltage/temp warnings, etc) configurable by serial.
    So there's not really any more room on the SDC board for more stuff. HOWEVER...
    the plan is to have an external addon board (this is where the expandable part comes in) that connects to the SDC via a 4-pin connector. since this board doesn't need to be inside the PSU, it can have as much on it as needed. This is where all the "fun stuff" will go... things like various temp and voltage monitors, relay controls, extra status LEDs and control buttons, serial communication with the computer, etc. etc.
    The reasoning being that this allows a SDC with moderate features (all the important stuff for an SDC to do, and comparable to the built-in SDC's of other PSU's) to be in the PSU, and anyone who wants more control or features can get the expansion board.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  3. #13
    Jul 2004
    Berkeley, CA
    Oh, is the SDC gonna have a serial port? If it will, it woudl be cool to have it send the car's battery voltage
    The expandable part sounds good
  4. #14
    Mar 2005
    Maine
    Quote Originally Posted by 0l33l
    yes, it is. And yes, it will be able to send car voltage readings, as well as the temp reading.
    I plan to make it so that standalone, the SDC will output that kind of info repeatedly, and accept commands from the computer to change the above mentioned settings.
    When connected to the expansion board, both the computer and the SDC will communicate with the expansion board, allowing access to information of whatever peripherals are on there.
    eegeek.net
  5. #15
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    I sent a pm to dragonBTV. evandude, I would prefer to talk about my ideas over pm if that is ok. I will send you a pm later today sometime.
  6. #16
    Quote Originally Posted by meddler
    you can say anything here instead of PM.
    I am an open one
  7. #17
    due to the limited space,
    I will leave a stand up or flat over head space for the SDC board, there will be a 14pin connection.
    the function of 14pin will be released here soon. (fan control should be inclueded in SDC)
  8. #18
    OVERHEAD mountting
    green---PSU PCB
    blue----14pin connector
    red-----SDC
  9. #19
    the PINS that could be choiced from
    battery input
    GND
    ACC
    main 12V
    main 5V
    main 3.3v
    SB 5v
    -12v
    -5v
    SB off(even turn off the +5v SB when ATX psu is already off)
    OFF
    kill FPC
    FPO
    PGO
    PSON
    PGI
    BUZ(faults alarmming)
    red LED (has input)
    green LED1
    green LED2
    green LED3
    kill fans
    fan yellow output(the speed control yellow line of fan)
    temp sensor(should tell me the detail of the sensor IC or R)
  10. #20
    BTW:
    a logic chip is already on board of PSU, it is TPS3510
    a 4mm hole is on the case for the SDC's serial cable
    Attached Files Attached Files
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  3. Does a 300w PSU need a 300w inverter?
    By Max018 in forum Power Supplies
    Last Post: 03-24-2004, 12:53 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
