Results 1 to 2 of 2
Thread: M1-atx
    I need some advice regarding the power wires. Can I connect both the + and switched wire together to a DC power source (+) in-house with the ignition timing scemes? The idea is to replicate the ignition behaviour. If not how can i input a switched line signal?
    Much appreciated.
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    The wire that goes from the M1 to the ignition switch is looking for +12v.
    Simply...if you take a wire from the +12v going to the M1, and connect it to the SW input, the M1 will start up.
    When you remove the +12v from the SW, the M1 will shut down (depending on the various timer settings)
    Leave the +12v connected to the power supply while doing this.
    (I assume you want to power up your M1 from an AC power adapter)
  1. M1 ATX problems
    By Tompa B in forum Power Supplies
    Last Post: 09-25-2005, 07:39 AM
  2. m1 atx it for me?
    By psycos in forum Power Supplies
    Last Post: 08-13-2005, 12:06 PM
  3. Whats happens -> M1 ATX combined power overloaded?
    By Me&you in forum Power Supplies
    Last Post: 05-09-2005, 04:28 PM
  4. mini ITX vs atx or micro ATX
    By kelseymonster in forum General Hardware Discussion
    Last Post: 04-26-2005, 12:56 AM
  5. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
