Results 1 to 9 of 9
Thread: Problem with M1 PSU and external Soundcard
    Newbie cyrax83's Avatar
    Aug 2005
    sydney
    Hey guys, need some help.
    I'm building my car pc and i've also bought the external USB Soundcard the Audigy 2 NX listed here
    http://www.mp3car.com/store/product_...roducts_id=105
    Anyway i'm also planning on using the M1 ATX PSU listed here.
    http://www.mp3car.com/store/product_...products_id=67
    The problem is that i thought the Audigy 2 NX was USB Powered. It says its 5V DC, it has some converter then a normal 240V Wall Plug on the end. I obviously cant connect it with the 240V because i'm not using an inverter, my question is can i connect the soundcard to my M1 Somehow ? And i hope it doesn't involve stripping too many wires with miniscule size
    Adwin
    Variable Bitrate numbers's Avatar
    May 2005
    Yes you can do it that way. I've never seen an m1-atx so I can't help you on the specifics. Someone else will be along shortly to tell you, though. It won't be hard.
    Aug 2005
    sydney
    anyone guys ?
    May 2005
    Oh come on guys. Will someone just tell him which wires to use to get 5v? Sheesh.
    Nov 2004
    Simply use one of the drives molex power connector, either by cutting the wire or way better by using a female connector you can find in any good store.
    The red wire is +5V, the Yellow is +12V, and the two black wires are ground.
    André
    May 2005
    And here I was thinking that the m1-atx didn't have any molex connectors. Sorry dude. I should have at least looked up the m1-atx before assuming I couldn't help you.
    Aug 2005
    sydney
    thanks, that helps. But does that mean i have to strip the wires on the power connecter go to the bare wires on the audigy ?
    Newbie HolySdrJR's Avatar
    May 2005
    Quote Originally Posted by andrel
    ...or way better by using a female connector you can find in any good store....
    Aug 2005
    sydney
    i meant cutting the bare wires on the audigy soundcard power cable...
  1. YAOP (yet another Opus problem)
    By Frankino in forum Power Supplies
    Last Post: 06-19-2005, 12:17 PM
  2. M10000 Boot problem
    By Multiplayer in forum General Hardware Discussion
    Last Post: 01-21-2005, 04:18 AM
