Results 1 to 7 of 7
Thread: Green/White Opus Power Switch Cable ?
    A-Z
    A-Z is offline
    Constant Bitrate A-Z's Avatar
    Feb 2005
    Atlanta, GA
    I need a replacement of the green/white power switch, where can I get one?
    Jaz
    Jaz is offline
    Apr 2005
    have u broke your one or lost it?
    will be easier to repair one i expect. but then ur in the US, so id give opus a call i expect they will send you one at a good price.
    A-Z
    A-Z is offline
    Feb 2005
    Atlanta, GA
    Yeah its damaged, i pulled the wire out of connector. Now carputer doesnt start.
    Jaz
    Jaz is offline
    Apr 2005
    pulled the pin off or pulled the pin out of the connector?
    the pin should be quite easy to put back in...
    but again opus will be ur best bet, drop them an email or something.
    A-Z
    A-Z is offline
    Feb 2005
    Atlanta, GA
    Pin out of connector
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    The pins are about the same pitch as an MPC-2 audio plug (you know, the usual 3 wire 4 pin audio plug that goes from ROM drves to your sound card) so if your really stuck you could hack one of those down?
    Variable Bitrate numbers's Avatar
    May 2005
    As Jaz said, just put the pin back in the connector.
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. I need the p4 power cable for the opus 150 for shuttle pc!
    By customalti05 in forum Power Supplies
    Last Post: 05-23-2005, 03:31 AM
  3. extend opus power cable?
    By john1701 in forum Power Supplies
    Last Post: 03-21-2005, 07:52 PM
  4. opus 150w no power
    By rainman in forum General Hardware Discussion
    Last Post: 03-09-2005, 03:39 PM
  5. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
