Results 1 to 10 of 12
Thread: Runnin an Opus 150W Shutyle revision (fanless) in a case...
    Raw Wave justintime's Avatar
    Apr 2005
    Running an Opus 150W Shuttle revision (fanless) in a case...
    I purchased an OPUS 150 for my carputer, the Shuttle model (without fan).
    This one: (DCX2.1215.XPC)
    I am planning on putting it in the case, along with the other stuff (mobo, + HD). It all fits VERY VERY tight, but it fits. There's like a 1/2" clearance all around for the Opus. (!).
    Am I being stupid? Will this thing generate so much heat that it will burn itself, or any surrounding cables/components?
    The case will have an exhaust fan, as well as a fan on the CPU. but no PSU fan.
    The attached Image shows planned location of Opus, outlined in yellow...
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Apr 2005
    Shameless bump. Anyone have opinions on this? Possible, not possible? Good/bad idea?
    2002 Honda CR-V
    Jaz
    Jaz is offline
    Apr 2005
    id like to get rid of the horrible noisey fan on my opus, so id be interested in this too.
    Its far to small and noisy for an incar pc.
    Apr 2005
    So, nobody knows about this fanless Opus? Or nobody cares? Need to know if this is dangerous or not!
    2002 Honda CR-V
    Jaz
    Jaz is offline
    Apr 2005
    yeah! cant believe no ones wondered this before. are they happy with the turbine they call a fan? lol
    Constant Bitrate Troy McClure's Avatar
    I run the same PS in my case although my case is not that tight fitting. The only fan that I have is on my CPU although the PS can conduct heat off to the computer chasis (metal chasis) whereas yours looks plastic?
    That particular PS is designed exactly that way to disipate heat using the thick aluminum housing and to not require a fan. It was also designed to fit into a shuttle that is tight without fans other than a direct CPU fan.
    I personally would think that as long as you have a fan moving fresh air in the case that you should not have an issue. Running it and testing it will be the ONLY true way to know for sure as most carputers are never the same.
    Troy
    Done!
    If you're into fishing, checkout my website! http://www.pennsylvaniaanglers.com
    Apr 2005
    Thanks Troy, very informative (and gives me some hope too!)
    I am planning to cut the plexi at the top, so the metal is exposed, and heat can be disipated out of the box. Any heat disipated to the interior will be dealt with by the case exhaust fan.
    I'll first try this without cutting the plexi, and if it is too bad I will try cutting the plexi and exposing the metal. Thanks!!!!
    Quote Originally Posted by Troy McClure
    Troy
    2002 Honda CR-V
    Apr 2005
    Update. IT FITS!!!!
    Preliminary tests show temperature will not be a problem, using only the case fan. Will post pics soon.
    2002 Honda CR-V
    Jul 2004
    Irvine, Cal
    Off topic but hey!!! lol. What kind of hand made case is that? Is that tupper ware i see?
    Apr 2005
    It is the original plastic drawer that slides under the passenger's seat.
    2002 Honda CR-V
  1. FS: Carputer (Opus Case, Epia M10K, 512 ram and more)
    By Darek85 in forum Classified Archive
    Last Post: 09-20-2005, 08:28 PM
  2. FS: Epia M10000, Opus Case, 512 ram, 30gb HD
    Last Post: 07-26-2005, 12:29 PM
  3. opus 150w no power
    By rainman in forum General Hardware Discussion
    Last Post: 03-09-2005, 03:39 PM
  4. my opus 150w for sale on ebay in the **UK**
    By jay18 in forum Classified Archive
    Last Post: 01-22-2005, 05:24 PM
  5. OPUS 150w keeps killing my battery. Need help!
    By EuroFan in forum Power Supplies
    Last Post: 10-20-2004, 08:04 AM
