So how do you buy this??
Based on a modified design of the M1-ATX, but with a stronger 12V rail, here are some preliminary specifications. Also, please see picture below.
NOTE: Microcontroller softtware remains the same.
MAX
5V 10A
5VSB 1.5A
3.3V 10A
12V 8A
-12V 0.1A
On the 12V rail, I was able to push it to 10A, but things got very hot....
Also, keep in mind that at full load you would need a fan to blow over the PCB, some derating will need to occur.
Please do not take these specs as final, some more testing / derating needs to occur.
Should you need a notification when the M2-ATX icomes out from production, please send an email to m2-atx@mini-box.com
Enjoy,
-A
Probably from the MP3car.com on-line store. You must be patient, this PSU is still in the quoting process, it will probably take ~2 months for the first lot to come out, should everything go as planned.
-A
Originally Posted by kickercivic1
Just a thought. If you can make ATX connector on a board 180 deg rotated so the snap in version can be something easy to have. And 10x16 capacitors is a must.
Car pc integration with ease
Car mediacenter
Yes, 10x16 capacitors! The above picture uses 10x20capacitors, easy to find.
Sorry -- the ATX conn is harder to rotate, need to keep the power traces as close to the output rails...
-A
Originally Posted by jbors
You mean you already have a mask board ? Understand. It will be a lots of rewiring for me thenOriginally Posted by andrewb
Car mediacenter
Rotating the ATX connector is possible, but wll be a massacre...
Keep in mind that M2-ATX am 'evolution' of M1-ATX. same footprint.
This formfactor was 'imported' from Morex, which makes PSU boards with the same formfactor. I thought it is a good idea to keep the same dimensions for the M1-ATX and M2-ATX, since a lot of cases are made for these boards.
Andrei
Very good news!!
My M1 almost got on fire last weekend, so I might need a new one![]()
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status --> Lilliput Installed (not indash yet..)
BraveCar 2.5
Will the M2-ATX shutdown if it is overloaded?
Yes!
OverCurrent protection is set for the 5, 5VSB, 3.3 and 12V.
-Andrei
Originally Posted by Zip-Lock
