Results 1 to 2 of 2
Thread: Newbie asking for help
    Aug 2005
    hi i'm new to this forum.i have seem a normal home pc install onto a car in this forum so i need to get some info.hopefully u guys can help as i'm a complete electronic idiot.
    i'm confused about the main battery connection to the pc.
    as i know that car is 12v but home pc needs a 230watt power to b able to use.
    i ever seem a 12v power inverter in my country which is able to convert 12v to a normal household 3 pin plug.
    i ask the salesman n he told me that any of the house electronic item are able to use in the car if i use it,but some of my friends told me that is very dangerous to use this inverter as the inverter draw 12v from my car n convert it into 230w,it may cos my car on fire.
    i need a clear n simple way to use my home pc on my car,do u guys can help me with it?pls don't tell me to buy a laptop thank you
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    You can absolutely use an inverter. You have to hook it up correctly, to avoid the fires, but that is not difficult at all.
    Battery -> fuse -> 8AWG wire (at the smallest) -> relay -> Inverter (also fused) -> Ground
    You are going to have to read up on how others have used desktops with inverters. The powering up, and powering down will be your main concerns.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  1. I'M not a NEWBIE anymore!!!
    By sansoo24 in forum Newbie
    Last Post: 05-01-2005, 06:42 PM
  2. help a computer BUILDING newbie out....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-11-2004, 04:39 PM
  3. how about a newbie section?
    By Zeeshan in forum Mp3car Forum Suggestions/Comments
    Last Post: 07-19-2003, 01:40 PM
  4. Replies: 2
    Last Post: 12-16-2001, 11:50 PM
