Results 1 to 10 of 14
Thread: Problem powering the following
    Variable Bitrate looneeii's Avatar
    Feb 2005
    Gatineau, QC, Canada
    Well after taking a good 2-3 days in customizing my setup in my GP for my new PC I run into an issue where after maybe 5-6mins the HDD reboots on it's own.
    Here's what I have setup:
    EPIA M10000
    512MB RAM
    40GB 2.5 HDD
    Liliput 8" TS screen (so one VGA port and USB touch)
    Microsoft 54MBps router - MIN-710 - USB
    Bluetooth Dongle (USB)
    Running on:
    PW-200
    Carnetix 1290.
    Optima Yellow top Battery.
    I have the LCD tapped into a the same 12 volt line PC but that shouldn't be a problem right?
    Anything anybody see?
    The PSU calculator says I'm ok with my setup with DVD playback being a top out at 72.9W.
    Should I give the HDD it's own 5V line from the 1290 or just keep it on the PC ?
    99 Grand Prix Grand Tigress
    HW
    Liliput 8in TS
    845GVD MITX w/ 2.4 Mobile P4M (478 MB)
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    "Should I give the HDD it's own 5V line from the 1290 or just keep it on the PC"
    Sorry if i misunderstood, but how is the laptop hd recieving its power now ? If there is other devices on the same power cable as it, that really shouldnt matter. but you could check for a voltage drop i suppose.
    Also keep in mind that when you first turn on most devices they use more power.
    and keep in mind the power calc is just a rough estimate.
    If you have a regular high watt ac-dc psu, i'd try that and make sure everything runs fine for more than 15 minutes or so.
    When you say the HDD reboots do you mean the whole pc?
    REBUILDING!!
    Feb 2005
    I meant using the molex connector from the IDE cable adapter to the PW-200. and yeah I can run everything off a 300W PSU just fine..
    HW
    Liliput 8in TS
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
    Elsewhere
    Search the forums for PW200. Do some reading. You'll learn a lot and probably be angry with yourself afterward.
    How about the Wiki?
    Aug 2004
    if you have a multimeter, you should test the 5v feed after like 13 minutes or so, and see if the voltage is dropping. I would also check and make sure the HD is properly disapating heat. The way you have the power set up should be fine, its how my is setup and it works good.
    REBUILDING!!
    Feb 2005
    Quote Originally Posted by DarquePervert
    Why would I be angry with myself?
    HW
    Liliput 8in TS
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
    Feb 2005
    Quote Originally Posted by Dragonknell911
    Will do.
    HW
    Liliput 8in TS
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    because it isnt really 200w at all... you will be angry with yourself for purchasing such a bad psu without researching enough... I would at least
    Roy
    2005 Range Rover 4.4
    Elsewhere
    Quote Originally Posted by RoyN
    DING DING DING!!!!
    We have a winner!
    Quote Originally Posted by looneeii
    You haven't searched and read yet, I see. I'll narrow it down for you:
    http://www.carnetix.com/additional_i...PeoplePlay.htm
    How about the Wiki?
    São Paulo, Brazil
    Yay send me the car!
    Roy
  1. audio problem
    By tiburonputer in forum General Hardware Discussion
    Last Post: 08-11-2005, 04:58 PM
  2. weird rebooting problem.. possibly power related...
    By mikevsgeek in forum Power Supplies
    Last Post: 09-04-2004, 02:21 PM
  3. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 02:38 PM
  4. ITPS powering problem
    By mmstudios in forum Power Supplies
    Last Post: 06-01-2004, 08:09 AM
  5. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 12:09 PM
