Originally Posted by
mushin
@Epridaz: 20A fuse is too big for 16ga wire. 16ga should be fused around 8A. For a 15A load, 12 or 10ga would be a reasonable size, with a 20A fuse.
@Silentbob: 18ga is more like 5A max; it's ok for the very short leads going into your PSU, but not for any real length. Your other wire size to max amps is right on. Regardless of what you use, it's imperative you fuse at the battery - the PSU fuse will protect things downstream from it (like your screen) but not the wire from the batt.
