[QUOTE=zeppelin]Folks,
I'm a newb here, so be kind. I'm installing a carputer comprising a laptop to a motorised 7" VGA touchscreen mounted in a DIN slot in the dash. Most of the install is done, and I'm presently hooking up the power supply to the laptop. This is where I'm having problems. BTW, my knowledge of electronics is rather minimal - just enough to be dangerous.
I have a 12vDC-12vDC car power supply that I bought for the laptop. I cut the cig lighter fitting off, and connected two bayonet fittings in it's place. In doing this, I assumed the inner core was (+) and the outer winding was (-).
Querie #1: Is my assumption correct?
Yes
I then tapped into an auxillary power source in the back (whick looks like it's for a CD stacker), and ran a separate line to ground. I connected the (+) to the aux power line and (-) to ground.
I booted up the laptop, turned on accessories power, and plugged in the adapter. The power light on the adapter then proceeded to cycle every couple of seconds between green and red, associated with an audible click from the adapter each time it went to red. The laptop screen also flickered with each click. Power management showed that the laptop wasn't charging. A mulitmeter showed the adapter outputing 17v. Specs on the back of the adapter are:
DC Input: 12v
Fuse: 13A 250v
DC Output: 18v - 20v 90W (max)
17 Volts is low.. the Outpu spec is dodgy, are u able to fix it at 19V? Also the input for a Auto DC-DC converter is in a range..e.g. 9v-22v or so.
The laptop spec is:
Input: 19v 3.16A
Querie #2: What am I doing wrong here?
try running your motor, the 17V output ur getting is typical of a DC-DC converter wanting more power and the lappy isn't getting it. It is a lot of fun but you want to throw it all away at times... keep trying..
Cheers
Peter
LinkBack URL
About LinkBacks
