Results 1 to 10 of 11
Thread: OPUS: how to restart the carpc after manual shutdown?
    May 2004
    NJ
    I know that OPUS will start/shutdown the pc upon getting/lossing ignition power. Question is, if, for some reason I shutdown the pc through the "start" menu while the car is running, I can't start the pc, I have to turn off the car, then restart the car - or at least put the key in the ignetion position.
    I know OPUS is doing what it should but how to override this, since OPUS controls the power switch on the mobo.
    Why am I asking, if a cop stops me, I would like to turn it off, then after he leavs, I would like to start the PC without restarting the car. It is not that I get stopped often
    Feb 2005
    Only a guess here, but if the OPUS senses current on the ignition feed which acts as the on switch, and the PC will turn on. When the OPUS senses theres no current on that cable, the OPUS will send on Off signal to the PC signalling it to shutdown. In theory, all you would need to do is fit an on/off switch on the ignition feed.
    Please correct me if I am wrong.
    Elsewhere
    Quote Originally Posted by kingtut
    Search the forums. There's a guide to putting in a power switch in addition to the Opus auto-on capability. You're not the only one who has wanted to do this.
    How about the Wiki?
    Tainted Love Cris's Avatar
    Romania
    That's why I have it hooked to the remote line of my head unit. Take the front panel off, or turn the head unit off, and the pc turns off.
    Jun 2005
    Kent, England
    i put in a on-off-on switch in the dash
    position 1. opus works as normal of ignition
    position 2. ignition signal cut, so the opus thinks ignition is off (handy for servicing/valet parking/police check)
    position 3 opus gets constant 12v so you can switch it on and off without the key in ignition
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    As above, if you have a valet switch in line with your ignition supply you can just pop that and the pc should restart (providing your ignition is on)
    May 2004
    NJ
    So simple, makes me mad why I did not think of this on my own. Thanks guys.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    You guys should always do this.
    ACC/IGN ------- ON/OFF SWITCH ------ SDC/PSU.
    The reason.
    couple minutes to the liquor store, the PC doesn't need to be on.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Quote Originally Posted by GreenBeast
    Any pics? Where did you get the switch?
    I want to do the same thing but am having a hard time finding a switch that I can add to my dash area without it looking odd.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by edrex
    Go to dealer. Usually around steering column, there are couple "dummy" switches where you find coin holder, foglight, hazard, defrog, ... switches (left or right of steering wheel). Get a ON/OFF switch and pop the dummy out and push that new switch in.
  1. Opus 90w Shutdown Power off Porblems
    By antimatter in forum Power Supplies
    Last Post: 04-15-2004, 12:24 PM
  2. Can you adjust shutdown voltage on Opus 150w?
    By Visual Echo in forum Power Supplies
    Last Post: 03-26-2004, 09:04 AM
  3. Random Startup and Shutdown with Opus
    Last Post: 03-08-2004, 06:47 PM
  4. Does your Opus 90 surive crank and perform shutdown?
    By quinxy in forum Power Supplies
    Last Post: 03-07-2004, 12:45 PM
  5. Idea for overcoming 5v drain on Opus when shutdown.
    By ShinkunoNamida in forum Power Supplies
    Last Post: 02-07-2003, 10:41 AM
