Results 1 to 10 of 11
Thread: power inverter power supply shutdown problem
    Newbie launter's Avatar
    Mar 2005
    Manchester UK
    Hello I have a LV-670M motherboard running a 1.7 GHz Mobile pentium .I'm having trouble with the power supply. Originally I had an OPUS 150W power supply. However the PC always shut down once windows had loaded up so I ended up getting rid of it and anyway prefferred to have the pc on a normal power switch so I could be the one rather than the car that decided when it turned on and also liked having the option of moving the pc into the house when needed. I now have an enermax 230w micro-atx power supply running off a 300W Nikkai power inverter. First time it loaded up but again as windows started it shut down. Whats happening ? The pc works fine when its run off the mains ? The inverter works fine for other equipment ! Now the pc won't power on at all and the inverter just clicks. Hells bells I can't figure out this elctricity stuff
    can anyone help
    your car might not be giving to a enough power
    Mar 2005
    Manchester UK
    Surely it could manage 230 watts !! I ran a 600watt drill fromt the power inverter and it seemed to work without problems ? How can I check whether the batteries giving enough power. If it is the battery whats the solution ?
    145 watt micro-atx power supply
    LV-670M motherboard
    1.7 mobile pentium
    600w pure sine wave inverter
    250gb hard drive
    Elsewhere
    The easy way to test this is to plug in the compute rinside and see that it powers up and boots into Windows.
    You may be having an issue with the Windows install or a failing piece of hardware that's causing Windoze to shutdown before it fully boots.
    How about the Wiki?
    Mar 2005
    Manchester UK
    Computer works fine indoors
    LV-670M motherboard
    1.7 mobile pentium
    250gb hard drive
    Sep 2005
    San Diego
    Sounds wierd... it was doing this before with the Opus, too? Hmmmmm.... I would blame the power inverter (maybe heat problems), but it has to be something on your motherboard.... try clearing the CMOS, maybe that'll help.
    Mar 2005
    Manchester UK
    yes, it used to do it with the opus but at that time the opus was wired directly to the battery (no inverter).now its still doing it and no opus just the inverter
    i wonder if its the motherboard, doesn't seem to make a lot of sense because it runs fine off the mains.whats going on !!!!
    LV-670M motherboard
    1.7 mobile pentium
    250gb hard drive
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    alternator is not pushing enough power to keep up with either the opus or the inverter. Also check your battery. I had the same problem. You need to get both a better alternator and battery.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Mar 2005
    Manchester UK
    test***es, that sounds expensive !!!!!!!
    LV-670M motherboard
    1.7 mobile pentium
    250gb hard drive
    try it is some one else car mabe a newer one
  1. 12v Power Supply at MP3Car.com store
    By mykolJay in forum Power Supplies
    Last Post: 02-02-2006, 10:17 PM
  2. Problem power supply for my monitors
    By edrex in forum Power Supplies
    Last Post: 09-03-2005, 12:51 AM
  3. custom shutdown controller for inverter usage
    By Vchat20 in forum Power Supplies
    Last Post: 02-28-2005, 11:59 PM
  4. Replies: 4
    Last Post: 10-29-2004, 09:10 AM
  5. Problem with my power supply?
    By ELEmental59437 in forum Power Supplies
    Last Post: 06-04-2003, 11:56 PM
