Page 13 of 20 FirstFirst ... 34567891011121314151617181920 LastLast
Results 121 to 130 of 194
Thread: 220 Watt DC-DC Power Supply: DSATX
  1. #121
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
  2. #122
    Oct 2005
    Denmark
    Quote Originally Posted by SnyperBob
    ahh, i see ?
    [*---------] 10% (Planning)
    Car: Audi A3 (got the car, need the rest...)
  3. #123
    FLAC alti's Avatar
    NY
    For everyone who was wondering whether or not this PSU would encounter the same issue as the opus with the biostar m7ncg 400, I can tell you that it has been working awesome on my system over the last 2 days. I have not changed anything yet on the DSATX just wired it up. I love the way that it works in comparison to the opus. The unmodified shutdown timing it ships with (20 minutes?) means that when I stop for gas or coffee I get in and turn the key and the computer is still running. with the opus it would have to boot back up again. It also only waits a second or so after iginition signal is sent(the opus was about 5 seconds I think) before kicking on so time to music is significantly shorter.
    I have not had any time yet to modify the settings and will be building my new setup with the ideq over the weekend after I get it put together I will post a review thread.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  4. #124
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I got the PSU, shot couple pix with the cell. Other than that, I didn't have time to disassemble my current system/instalation to install this PSU. Hopefully it works much much better than my custom Sproggy . Hey I am happy with the Sproggy, and this PSU should be much better cuz it was made/designed by a PRO.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  5. #125
    Apr 2001
    Portland OR
    Quote Originally Posted by alti
    It ships with a 20 minute variable timing set by P1, which defaults to the middle of the rotation, so it is more like a 10 minute default..
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  6. #126
    Newbie cell21633's Avatar
    Sep 2005
    Chicago, IL, USA
    ooh crud..i hit a snag. the psu is just a hair too big to fit within the case i'm using i'm either gonna have to construct a case for the psu, or contruct a new case for the entire computer..
    u said u were going to design a case for this psu/ how soon would that be/
    i was able to do a quick simple test with the psu yesterday, worked flawlessly.
    RED 1999 ACURA INTEGRA GSR STOLEN -- CHICAGO 02/27/08
    VIN JH4DC2391XS002416
    PLATE ILLINOIS 5287412
    Team Integra Markings on Rear Quarterpanel Windows
    REPORT TO 911 IF FOUND
  7. #127
    Oct 2005
    Denmark
    Quote Originally Posted by zootjeff
    -Jeff
    but will it start my amplifier with a 10 second delay so i don't get i thump in my speakers? this is not clear to me? how would i wire that? is it the AUX SW that i would use for that?
  8. #128
    Sep 2005
    Jeff,
    Just a short note to let you know that I received the power supply on Saturday and have done an initial install in the van. First impressions are very favourable. The quality of the board and component placement show that a lot of thought went into this board. I can find no fault inthis area whatsoever.
    Hookup was staright forward. I ran 10 guage lines to Vcc, Gnd and am using a SPDT switch to control the ACC line……OFF, ACC Vin, and Batt Vin. This gives one some options in controlling the power supply.
    Have not yet had an opportunity to interface via serial, but will be trying that later this week. Everything is working flawlessly at this point. The power supply barely gets warm running my configuration….I will get the probes out when I get a chance.
    One option I would like to see implememted is the ability of the computer to go into standby mode and have the supply monitor battery state and shut down when a critical level is reached….I am sure this is doable with the microcontroller.
    Your documentation, although fine for me, will have to be elaborated upon for all the non tech types out there.
    You have developed a great power supply and I will keep you informed as I do more testing ……
    Currently being powered by DSATX:
    VIA SP13000
    3.5” WD 80 Gig
    DVD/CD RW
    512 ram
    2 case fans
    7 USB devices (so far)
    7” touchscreen
  9. #129
    Apr 2001
    Portland OR
    Quote Originally Posted by knrj
    Yes you have to use a relay on the AUXSW to get it to work right. Basically, hook one of the pins of the relay coil to the Aux pin. Connect the other pin to VIN or battery (+12 volts). THen when the unit is on, it will turn on the relay. It will turn off when the computer turns off or before, depending on which mode you have set.
    www.mpegbox.com
  10. #130
    FLAC alti's Avatar
    NY
    I have verified now that the DSATX works with both biostar motherboards. Overall my experience with it so far has been very good. There was one occasion where my computer did not survive a crank, but i was installing it today and had been using the battery extensivly without the car running. I spent most of the day today weeding through the onslaught of usb and com port problems, but it is now up and running correctly in the new system. Hopefully I will be able to post a thread with more detail tomorrow.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  1. DIY DC power supply???
    By lopan in forum Power Supplies
    Last Post: 03-23-2007, 01:18 PM
  2. FS: OPUS 150 watt DC-DC power Supply
    By wh0k in forum Classified Archive
    Last Post: 03-25-2005, 05:56 PM
  3. FS: Car Power Point , PSU, Power Supply DC - AC Converter
    By m_lazell in forum Classified Archive
    Last Post: 03-21-2005, 05:11 PM
  4. OPUS 150 watt DC-DC power Supply for sale
    By audia4carputer in forum Classified Archive
    Last Post: 02-27-2005, 01:20 PM
  5. found a new dc to dc power supply for VIA EPIA owners
    By Squeezer in forum Power Supplies
    Last Post: 11-23-2003, 01:22 AM
