Parvo,Originally Posted by parvo99
I plugged mine into my car and drove around with the same system you saw. Everything worked just fine. One thing I noticed is that I only had a 2 second window set for the low votlage setting. Basically when I cranked my car for 3 seconds it would cause a shutdown. But then if it cranked for 1 or 2 seconds, it didn't cause a problem I re-programmed it back to 10 seconds and it wasn't a problem during cranking. (It wasn't browning out, the regulators can handle it no problem, it was just fooling the SDC.) If this becomes an issue, I'll load the new code for you.
-Jeff
LinkBack URL
About LinkBacks
