Originally Posted by Scouse Monkey
“There are features that are built-in for trouble-free and safe PC operation. The input power is protected against transients, load dumps and double battery during jumpstarts”.
The DSATX has load dump protection. That is when the voltage at the input goes up to 60 volts because the battery got disconnected and the alternator is still connected. The DSATX has a Transient voltage suppressor that takes care of Load Dumps, and over voltage (double Battery, etc)
The DSATX will operate up to 24 volts on the input without damage. The regulators are designed power to a computer with an 8-16 volt constant input. It will operate down to 6 volts and up to 24 volts though. So If I used M1-ATX marketing, I'd say 6-24 volts, if I use wording I find fare and reasonable, I'd say 8-16v. I'll probably put down 6-24 as the main thing on the spec and then say something smaller for full load. Hmm, what do people really care about?
When you get a reverse voltage, load dump, or way over voltage condition, the Transisent voltage suppressor will clamp the input to 24 volts. If there is enough current, (reverse voltage, or large over voltage) the fuse will blow. This is the same technique I did in the MPBS1, uSDC20D and the M1-ATX and Opus all do this. When the transient voltage supprssor fails, it shorts to ground causing the fuse to blow even faster.
-Jeff
LinkBack URL
About LinkBacks
