Results 1 to 10 of 15
Thread: Fusing cable....
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    Ireland
    Fusing cable....
    Hi,
    My battery terminal to disty block 0AWG is run, and I plan to use 4AWG from thereon in. It's fused about 9in from the battery, with a 240A ANL fuse.
    The amps (JBL 1201.1 and 75.2) have fuses in them already, 120a and 20a respectively. Should I bother fusing between the disty and amps or is that just overkill?
    Great...system's on its way in...and then one of the coolant hoses packs in lol
    1996 Volvo 850 T5 CD - Eventually I'll start....
    Tainted Love Cris's Avatar
    Romania
    Yes, definatly put a fuse on every line going out of the distribution block. Better yet, get one of those blocks that already have fuses in them. You're talking about a really powerfull system, so don't take any chases.
    Apr 2005
    Ireland
    yeah. Thought as much. off to Maplin to get a few meters of 4AWG.
    Damn alternator better hold up until I can find a proper HO one.
    I was running the sub off the 75.2....and it began to relocate my rear view mirror
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Do as Cris said, get the distro block with the fuses build in it. The fuses after the distro block are not used for protecting the amps, the fuses on the amp serve that purpose. The fuses after the distro are used to protect the power wire itself. The wire can catch on fire and then you have a serious problem. So you should definetly fuse the wires after the distro block.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Romania
    Quote Originally Posted by Psychobiker
    Just you rear view mirror? Dude, TURN IT UP! (after you get it fused).
    Apr 2005
    Ireland
    Lol yeah. The 1201.1 was wired up (just to check if it came on) and it makes an ominous click on startup...yikes. this is gonna scare me I reckon lol.
    Seen what it's connected to?
    L
    Apr 2005
    Ireland
    three cubic feet. 28Hz. 1200 watts.
    Romania
    What sub is that?
    Apr 2005
    Ireland
    Resonant Engineering SE 12"
    Dec 2003
    New York
    very good choice.
    Installed
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 01:55 AM
  2. Need help on extending the Lilliput cable
    By nthai in forum LCD/Display
    Last Post: 04-27-2005, 12:59 PM
  3. where should i go to get a cable?
    By blackpacu in forum LCD/Display
    Last Post: 09-08-2004, 12:25 AM
  4. Wanna extend your Kiosk 12.1" LCD cable?
    By CDesigns in forum LCD/Display
    Last Post: 05-13-2004, 09:10 PM
  5. A cable I found.
    By masterful in forum LCD/Display
    Last Post: 08-17-2003, 09:36 PM
