b) alternator is messed up
c) voltage regulator in on the alternator is messed up.
I put a new battery in my explorer this past winter, and then I got the m1-atx (I was using a morex, also good PSU).
with the M1-ATX I was using suspend to ram and it would last till morning for for a few months, then I noticed my voltage was sitting at around 12v even while running, not the usual 14 or more.
so, does this mean
a) battery is going
Shawn
I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
Check out my web company Minneapolis Web Designer - Himmelberger Design
could it be one or the other.. or both.. how might I diagnose this?.. thank you for the help!
Shawn
your alternator & regulator are serviced as an asembly..... get a good remanufactured unit.... motorcraft, don't be surprised to see companys like bosh & delco also posibaly offering a unit for your truck.... stay away from generic auto parts rebuilts
if you've added amps & stuff you may want to consider an upgraded alternator also...
there look to lestek or stinger, possibaly fosgate..... there are others....
would 130amp do it?.. a local place has a used pulls at that amperage
Shawn
130 amps is on the upper end of what's factory available.... I guess go for it if it's cheap enough..... I would prefur to put something in that I would'nt have to worry about again for a few years..... a used alternator is a little iffy.., probably better than a cheap rebuild though...
