Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Invertor and CarPC pro shutdown controller issues, could use some help
  1. #11
    I forgot to mention, before doing step 1, make sure None of the jumpers are On.
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
  2. #12
    Falls Church, VA
    Tried it and the same thing happens, amplifier turns on and off before pc even with #11 at 255 ms. Everything else is working fine.
  3. #13
    Sorry for the delayed responce.
    The only other cause of this could be that the PC's +5v rail does not power up soon enough after the power signal is sent to the PC. This can only be corrected with a new chip.
    If you like, we will send you a new microcontroller so you can see if this will correct it.
    KyferEz
    Copper Wire Data
  4. #14
    Falls Church, VA
    Yup, lets give that a try. It seems to do it twice sometime nows.
  5. #15
    Ok, check your private message and we will arrange for the replacement chip tp be sent to you.
    KyferEz
    Copper Wire Data
