The ignition wire goes to any switch 12v source, i.e. a 12v source that is only on when the key is turned to the ACC or ON position. On most vehicles, you can tap into the 12v for the stereo (assuming it's on a switched line, of course) or a cigarette lighter. You can also tap into a switched line from the fuse panel.
The M1 senses
power on this line and will start up/shut down the PC.
This is ridiculous advice.
The M1-ATX has a times shutdown controller that will leave your PC on for a period of time. It's set by a jumper and the settings are outlined in your
user's guide.
