Results 1 to 10 of 13
Thread: Power draw for Shuttle system
    May 2005
    Hello all,
    Does anyone know what the approx 110V power draw in watts would be for:
    Shuttle P4 2.8 System
    No optical drive
    80 GB desktop HDD (Can be replaced with notebook drive)
    256MB RAM
    USB GPS
    Possibly a WiFi card
    Powering 7" Xenarc from the 12 v rail
    The current 12V power outlet in my car is rated at 120watts, and my digital inverter says that my Centrino laptop pulls 65w.
    I did search, but found nothing specific to this.
    Thanks!
    Constant Bitrate anik321's Avatar
    Nov 2004
    power outlet as in the cig. lighter port ?
    you will definitely not be able to run a p4 shuttle from there.
    i run a shuttle 2200+ with a 400W inverter, but the inverter runs straight from the battery with a relay switch in the middle from the ignition.
    99' V6 Solara SE.
    '05 CBR600RR
    Baltimore MD.
    Shuttle XPC| 512MB | 120GB 3.5" Seagate
    Opus 150W PS | Rikaline 6010 GPS
    7" Lilliput 619 | Centrafuse | IGuidance 3
    Variable Bitrate numbers's Avatar
    May 2005
    I can't imagine it pulling more than 120 watts, but you never know until you know. Can you not hook it up to that digital inverter of yours and see what it says? I'd bet a few bucks that it will run ok from the cig lighter, but don't forget that it would probably lose power when you turn the key off.
    May 2005
    Gotta love conflicting replies!
    Thanks so far!
    May 2005
    Sorry. I seem to do that a lot. I don't mean any offense to anyone by contradicting them. I just don't like misinformation on the net and like to pitch in to avoid it wherever I can.
    Try searching for various threads where people have actually measured their power consumption. You'll find that only the most power crazy systems draw as much as 120 watts. And again - can't you just hook it up to the inverter that tells you what the wattage is so you can see for yourself?
    May 2005
    Quote Originally Posted by numbers
    I could, but with my luck I would end up blowing a fuse somewhere...
    If it is any help, it is a 220w power supply in the shuttle. Now if that is at 12v, ... not sure how to do the conversion to draw at 110v
    Thanks for the help tho!
    May 2005
    Watts is independent of volts.
    Or, to put it more properly...
    Volts x Amps = Watts
    Watts / Amps = Volts
    Watts / Volts = Amps
    Jul 2005
    I ran a P4 2.4 dell off my 400 watt inverter through my cig lighter adaptor. It had no problems. The digital readout on the inverter said it was pulling around 90 watts on average.
    May 2005
    Plugged it into the inverter, turned it on, and it pulled 140w... unplugged the inverter before I melted my car Oh well.. must look at another option.. too bad, because I had a shuttle that I wasn't doing anything with.
    Now, again with this conversion thing, if the inverter's "Power out" is 140w at 110V, does this mean I am pulling more than the car's rated system of 120w at 12V thru the cigarette lighter?
    Thanks for everyone's help, I just don't trust my knowledge of electrical systems and conversion abilities to risk frying something in the car (even if it is a simple fuse)
    May 2005
    Quote Originally Posted by sebberry
    Yes, but the inverter doesn't draw 140 watts unless something is drawing 140 watts from it. There is no way in hell that your setup drew 140 watts unless there is something wrong with it. The fact that your cig lighter fuse didn't blow helps confirm this. Do you have a friend who has some experience with car electronics and whatnot? Getting this sorted out would probably be a rather trivial task if you can get someone to assist you in person. I wouldn't go looking for other options unless you just really can't find someone to help you with this.
  1. daft question, how much power does the inverter draw ?
    By launter in forum Power Supplies
    Last Post: 09-26-2005, 11:51 AM
  2. Replies: 1
    Last Post: 06-25-2005, 02:20 PM
  3. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
  4. FS: UK 12V Power system + Tank Circuit
    By Jamez_Warner in forum Classified Archive
    Last Post: 03-02-2004, 02:04 PM
  5. Power system
    By Dishnu in forum Power Supplies
    Last Post: 07-01-2001, 07:56 PM
