Results 1 to 1 of 1
Thread: Dry battery
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Dry battery
    I have made power control system to be sure, I not com to my car and the battery is empty
    Function
    The switch block with pin 1,2,3,4 and x
    It can only one connection form 1,2,3,4 to x at the time
    1 to x = always power
    2 to x = power when the radio switch to CD aux function
    3 to x = power when the radio is ON
    4 to x = power when you start the car..
    If you use the 1 to x function, the controller sound every 5 sec, if you press reset the sound stop , itīs because the system can dry you battery in this function ( if you forget it )
    This 4 function give you opportunity have power on the system all possible way
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 12:45 PM
  2. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  3. time to a dead car battery?
    By chuckctv in forum Newbie
    Last Post: 08-24-2004, 03:47 PM
  4. time to a dead car battery?
    Last Post: 08-20-2004, 11:08 PM
  5. Problem with tank battery - any good Plan B?
    Last Post: 06-14-2004, 10:10 PM
