Will that screen handle varying voltages? You may want to place it on a regulated 12 volts. Whether you tap it off of the PSU or get a Cartech unit, its up to you.
n/m, reread your post. Looks like it will
Answers:
1 You want a large fuse at the base of the 4 gauge, within 12 inches of the battery. Once you get to the point of aa distribution block to break up the 4 gauge for the other components, I fuse there as well. Prevents items from taking out other items due to power issues and allows a quick way to kill power. You will want to use appropriate fuses for these items.
2 The CarPC is what I run. Look at their website for info. It will need a power, ground and accessory run. Then there are wires for the PC and two more for the invertor. Basically I tapped power from the ditribution and ground block. I placed it on the same fuse as the invertor. I ran a wire back for accessory and connected that to the harness where the stock radio was.
3 well perfect would be 2.5 and 8 amp fuses. Otherwise 5 and 10 amp fuses are fine
LinkBack URL
About LinkBacks
