Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: stanard atx dc-dc conversion
    Nov 2004
    i have a couple of old atx psus here and was wondering if these can be converted to dc-dc for carputer, im not too worried about them cutting out while cranking, basically i just want it to take the 14 ish volts from the battery and use it to run the pc
    any suggestions
    thanks
    ps. i read presslabs post and i dont need it to go down to 7.5v
    Nov 2004
    basically i want someone to tell me what parts to remove so i can feed it from the battery
    Elsewhere
    It's not that simple.
    How about the Wiki?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Yeah, if only the transformer dropped the 240AC down to 12VAC and then had a bridge rectifier on it to get 12VDC and -12VDC.
    Apr 2002
    Houston, TX
    It's very easy, you just remove the large yellow thing with 12pF on it, turn it around, re-solder to the board... then the tricky part... you have to purchase a "Pico-Nano-Electro disapater" in the range of 12.32 to 18.61 Ohms and this has to be jumped in between pins 13 and 36 of the IC marked C4426-P2, and it must be the IC on the left, not the one on the right.... just below the blue round thing approx. 0.345" in diameter, not the one below the blue round thing approx. 0.385" in diameter....
    I have done it many times, just be slow and you will be set.....
    If you have any problems let me know I can send some pictures
    Nov 2004
    a what "Pico-Nano-Electro disapater"
    Variable Bitrate numbers's Avatar
    May 2005
    omg omg pix plz!!!!
    Newbie cell21633's Avatar
    Sep 2005
    Chicago, IL, USA
    all in good fun
    RED 1999 ACURA INTEGRA GSR STOLEN -- CHICAGO 02/27/08
    VIN JH4DC2391XS002416
    PLATE ILLINOIS 5287412
    Team Integra Markings on Rear Quarterpanel Windows
    REPORT TO 911 IF FOUND
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    no but is this sort of thing really possible, with keeping the power output of the atx psu the same? because my system requires a minimum of 300W so I have a 350W atx psu, but it would be nice to get rid of that inverter
    Debating on installing a carpc in my Jeep.....
    May 2005
    Yes, but it's not as simple as you may hope. Search the board.
  1. DC - DC ATX current drain?
    By l9nux in forum Power Supplies
    Last Post: 08-27-2004, 08:04 AM
  2. Replies: 15
    Last Post: 06-24-2004, 10:49 AM
  3. what is the cheapest DC to DC ATX power supply available?
    By Squeezer in forum Power Supplies
    Last Post: 07-29-2002, 02:17 PM
  4. What are the ATX DC to DC power supply options?
    Last Post: 07-08-2002, 05:25 PM
  5. atx dc dc
    By tre in forum General Hardware Discussion
    Last Post: 12-17-2000, 08:24 PM
