Results 1 to 3 of 3
Thread: power inverter problem. help
    Oct 2005
    I got a 300w power inverter that doesnt work when i wire it to the battery but it will work when i plug it into the cigarrete lighter. i ran 4 gauge wire with a 50 amp fuse by the battery and 4 gauge ground. the voltage is the same as the cigarrete lighter. since im getting the same voltage the connection must be good any ideas or something i dont know about?
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    wire bad unless it is a different termial for each.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
    Oct 2005
    Just tried it out with out the fuse connected to the battery and it works. What fuse do i need? I have a 5AG-50A fuse. the output power for the inverter is 300W / 2.6 A continuous and input is 12 VDC 40 A max
  1. Replies: 8
    Last Post: 08-23-2005, 12:43 AM
  2. 300 Watt POwer inverter Question XBOX RELATED
    By Porgieanne316 in forum Power Supplies
    Last Post: 07-21-2005, 10:59 AM
  3. FS: VECTOR MAXX 700 Power Inverter
    By muldrick in forum Classified Archive
    Last Post: 10-23-2004, 09:41 PM
  4. Inverter Power - Autoelectrical q
    By MerlinDaHapyPig in forum Power Supplies
    Last Post: 03-16-2004, 03:26 AM
  5. Power Problems Please Look
    By kmfdmk in forum General Hardware Discussion
    Last Post: 02-15-2004, 09:39 PM
