Results 1 to 9 of 9
Thread: M1-ATX + Installation = Dead Battery
    Newbie HyDroLiC's Avatar
    Oct 2005
    Malaysia
    Hi Guys,
    Me and a friend just purchased the M1-ATX. We both installed it the same way. Only thing is he got the computer from travla.box and I built my own.
    A week after the installation both our car batteries were dead. Wondering if this is a problem with the wiring?
    We DID NOT pull the wiring from the car battery directly. Got it somewhere from the dash board. Probably the same wiring set up as a car amp would have. We got professional sound system guys to do it for us.
    The wire comes alive only when the car is ON. So if I turn off the ignition, all power to the M1-ATX should be cut off. We also joined together the ignition wire with the + wire.
    On top of that I have a switch that allows me to remove the wiring completely to the M1-ATX. This allows me to remove the computer from the car.
    Can anyone see why the car battery went dead?
    Is this a wiring problem? an M1-ATX problem? or the alternator not powerfull enough to recharge the battery?
    The jumper settings were also at B (2 = 5sec / 2 hours)
    My computer specs:
    Pentium III 800
    20GB 2.5 hard disk
    512 RAM
    Built in Sound & Graphics
    USB Mouse & Keyboard
    Oct 2005
    Malaysia
    anyone have any ideas?
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    Did You Say You Joined The Ignition Wire With The Battery Wire? If So Thats Definitely Your Problem!
    Variable Bitrate StrataG's Avatar
    Aug 2005
    New York
    Quote Originally Posted by HyDroLiC
    If you have your power feed and ignition feed coupled, your PSU will be trying to supply power until there is no juice in the battery (unless there is a low voltage cut-off on the m1-atx). There is a reason why the ignition wire is seperate. It tells the PSU whether to turn on. Are you sure that your computer is actually turning off? It should not be if what you said is the case, and there in lies your problem.
    Elsewhere
    I wouldn't trust that professional ever again!
    How about the Wiki?
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    The + should always have power no matter what state the IGN is in. Thats so when you leave the car it can shut the PC down correctly...
    Then when the IGN is hot it turns the PC on, of you joined the IGN and + then you lose all the shutdown features since it is killing power when you turn off car... not smart!!
    I always had the + connected to the battery for over as year and never a dead battery, its obviusly not wired correctly since you would see a lot more people with complaints if it was a problem with the M1-ATX.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Jan 2005
    Chicago, IL
    Yeah But Also If He Connected The Ign And + Together Wouldnt It Also Turn Everything In The Car On? Like His Radio And Amps Or Whatever?
    Mar 2005
    NYC
    (+) goes to the battery with a 10A inline fuse
    (ign) goes to ignition or ACC ( this is the connection in the middle of the 3 terminals on the M1-ATX
    (-) goes to ground
    I have mine setup on Jumper B. I also have a switch in between my ACC and M1-ATX for those times I just don't want it on. If I shut my car off, pc shuts down and I hit the switch the pc boots up again. Maybe your pc is still running and you didn't realize it. Therefore, you have a dead battery?
    Oct 2005
    Malaysia
    Thankz for the advise guys. Have to go back to the shop and get the wiring redone.
    I will follow DK888's setup.
    (-) goes to ground
    But im pretty sure no power goes to the pc when the car is not on.
    Because the light on the motherboard goes off when the car is off.
    Anyway will get the above done and let you guys know how it went.
    thankx.
  1. time to a dead car battery?
    By chuckctv in forum Newbie
    Last Post: 08-20-2004, 11:08 PM
  2. Dead ATX PSU(s)
    By kefka_killer in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:13 PM
  3. Using Battery Charger in the House?
    By dug1967 in forum General Hardware Discussion
    Last Post: 05-14-2004, 11:55 AM
  4. Battery dead in car. Opus?
    By Chairboy in forum Power Supplies
    Last Post: 05-13-2004, 01:06 AM
  5. Laptop battery died
    By jol in forum General Hardware Discussion
    Last Post: 08-22-2003, 04:55 AM
