Results 1 to 3 of 3
Thread: Custom mount for my OPUS 150W in ATX case
    May 2005
    Custom mount for my OPUS 150W in ATX case (PICS!)
    I've searched and searched for this type of thread, but haven't found anyone with pics. I know I have new status, but its because I've searched and searched before asking any questions or creating any new posts. So please don't flame, hehehe
    LOL, with my disclaimer out of the way, I present to you my sunday afternoon project of creating a way to mount the OPUS 150w power supply in my Aspire X-Qpack MicroATX case. Eyeballing the Opus against the factory power supply showed that it was smaller, and wouldn't fit the stock mounting points. So I began my quest to make it fit. I went to my local Home Depot and purchashed three of the following metal brackets:
    They were about $0.70 each, and seemed to fit what I was looking for (with some modification of course).
    Here's the stock PSU in the back:
    And here's the hole I needed to fill:
    So I get home, and try them out. Looks like they'll fit. I decided to use one stock mounting point from my case for the opus, the lower left corner, I added a washer, otherwise, the screw would push against the board inside.
    Sorry to jump steps, I basically mounted the bottom left corner losely, and would hold the plate up to see how much to cut. This was the hard part, since a hacksaw would take all day, so I used a jigsaw with a metal blade, the blade shook the bracket a little bit, and bent it slightly, but a hammer on a flat surface fixed it quickly. I then used a metal file to get all the rough spots out. My focus of the project was for a solid mount, and not for anything stylish.
    After a couple test fits, heres the progress:
    Came out pretty nice, I just had to open up the Opus and move the power plug to the backside (reason for the hole there).
    Top view of the mounting.
    Side view with the un-moved power plug.
    Back shot, with the stock PSU hanging off on the right hand side (didn't want to remove it quiet yet, since I was still in the bench testing mode.
    Shots of the mounting outside of the case:
    Here it is with the power plug moved, and all mounted up:
    So thats how I custom mounted my opus, I hope this helps others out trying to figure out how to do something similar.
    Any constructive comments or suggestions are welcome.
    Low Bitrate Strgazr's Avatar
    Mar 2004
    Blanchard, OK
    Good work! Very nice write-up also. It should be a lot of help for others.
    Thanks!
    May 2005
    Thanks, and for reference, its a SimpsonŽ Strong-Tie, part #: TP15. One thing I forgot to mention, is that its feels rock solid when you try and wiggle the Opus from inside the case, so you can tell its not going anywhere.
  1. Painting Ampie Case
    By semovodka in forum General MP3Car Discussion
    Last Post: 10-08-2005, 05:37 PM
  2. Opus CarPC Case .. anyone have it?
    By replicant in forum General Hardware Discussion
    Last Post: 09-29-2005, 07:09 PM
  3. Yet another opus 150w problem.... (this one's brand new)
    By iamConceyted in forum Power Supplies
    Last Post: 06-12-2005, 09:58 PM
  4. does the opus 150 mount in a normal atx case?
    By mattress in forum Power Supplies
    Last Post: 04-18-2005, 10:09 PM
  5. Will an OPUS 150W fit in a standard ATX Case?
    By hd54321 in forum Power Supplies
    Last Post: 03-30-2005, 05:38 PM
