Results 1 to 10 of 13
Thread: oh for gods sake help me, OPUS problem
    Sep 2005
    ok, ive been searching for an hour, no solid answers..
    1) have the opus hooked up properly, it turns on, stays on
    2) the mobo works 100% when hooked up to my atx desktop power supply
    BUT
    when i hook the OPUS up to the mobo, i get fan spin, hdd spin, but no vga. sometimes i get an annoying beeping every 2 seconds.
    what in the HELL is wrong. what a terrible way to start of this project
    let me guess? ill have to ship it to opus to have them test it?
    Opus 120w
    Via M10000
    512 ram
    60g hdd
    -Abe
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    what is the LED in the OPUS doing?
    Sep 2005
    staying on
    Tainted Love Cris's Avatar
    Romania
    If the Opus led stays on, that's a sign it's working properly. If you say you hear a beep when it boots up, then you might want to check some of the other wiring you did in there...What mobo do you have?
    Jan 2005
    The graphics card or memory probably isnt seated propery. Both would cause post beeps. Power problems rarely do.
    Sep 2005
    i have the m10k and when hooked up to the atx it works 100% fine, so i dont think the onboard video nor the ram have any issues. ONLY when hooked to the opus does it not post. this is so frustrating...
    Maximum Bitrate buurin's Avatar
    Sep 2005
    Seattle, WA
    Have you manually checked the voltages coming out of the OPUS with a meter?
    I dont know for sure(in fact this is a complete guess) but it sounds like everything that turned on is the 5V stuff, maybe the 12V isnt right.
    The fact it turns on using the desktop power supply is a good sign in my opinion.
    B Smoov
    Project Status: 90% Complete
    Next Step: TIVO for Radio
    Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
    Romania
    I still hope it has something to do with the wirring...but if you say that in the car when you put an AC PSU everything works then you got me...maybe you should contact Opus, see what they have to say.
    You could try and start the PSU only with the mobo and HDD plugged in, nothing else. If it works try plugging the VGA cable in from the monitor assuming you're powering it from the Opus.
    Low Bitrate Gene's Avatar
    Jun 2004
    Minnesota
    I have the same problem with my OPUS DCX3-120 and M10000 mobo.
    Works with external PS, no post/video with Opus. I had it working with my old M10000 mobo and Opus 90W. Called Opus, called Epia. Opus tested fine. Will try to get an RMA from Opus.
    Here is my post.
    mrcoolgli had the same problem. I'll try his suggestion tonight when I get home.
    I can't wait to figure this out. I miss my carputer!!!
    Elsewhere
    So resurrecting a two-year old thread is going to help your plight?
    How about the Wiki?
  1. Opus power up problem
    By baef in forum Power Supplies
    Last Post: 10-23-2005, 08:00 AM
  2. 86% Efficient AC-DC ATX supply
    By auto_robotics in forum Power Supplies
    Last Post: 11-25-2004, 03:16 AM
  3. Strange Opus 90W problem
    By Jailer in forum Power Supplies
    Last Post: 11-02-2004, 02:16 PM
  4. random, rarely occuring shut-down problem (using opus 150w)
    By Nav_Attack in forum Power Supplies
    Last Post: 04-12-2004, 02:20 AM
  5. OPUS powerdown problem
    By neutral in forum Power Supplies
    Last Post: 03-10-2004, 10:33 AM
