Results 1 to 10 of 20
Thread: Unusual inverter noise problem
    Newbie launter's Avatar
    Mar 2005
    Manchester UK
    When I first plugged my Sterling pure sine 150w inverter and turned on the computer there was an awful lot of noise. I subsequently grounded the case of the inverter to a common ground with the amplifier for my sub. Noise went 90% away.
    Question is, why cant I get rid of the rest of it . It also occurs when the computer is switched off and not even connected to the inverter !! It only occurs when the inverter is switched on. (out of interest I tried an RCA ground loop isolator when the computer was on and it made the noise worse !!!!!!!!)
    Any suggestions ? I think I 'm going to try a different ground to the sub, maybe thats whats causing the interference
    145 watt micro-atx power supply
    LV-670M motherboard
    1.7 mobile pentium
    600w pure sine wave inverter
    250gb hard drive
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Try this: Turn off the computer and disconnect the inverter. Did the noise go away? If so, the noise is being generated by the inverter itself and I'm not sure of any solutions to this problem other than switching to a DC-DC power supply intended for Car PC use.
    Want to:
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    move the inverter to the front of the car and use very short thick wires on it, connect direct to batter, use a long 110v/220v wire
    long DC leads cause hell
    Does that make any difference?
    Mar 2005
    Manchester UK
    Its definately being generated by the inverter. Can you get anything to put in position between the inverter and cigarette socket that will take away the noise ? Not willing to get a dc-dc supply as I need to bring the computer into the house frequently. Before when I had an opus it was too much hassle. Now the car computers working perfectly with the inverter and I dont want to fiddle with it.
    LV-670M motherboard
    1.7 mobile pentium
    250gb hard drive
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by launter
    you should not be getting your inverter power from the cig. socket.
    Run power from the battery. This has been covered in ecery thread about noise and power.
    TruckinMP3
    Read the FAQ!
    Maximum Bitrate DeltaFX's Avatar
    France
    Pure Sine ? that's just its brand name, uh ? Not related to any real sinusoïdal signal shape ?
    Real pure sine inverter usually cost twice the price of a opus 150W...
    Mar 2005
    Manchester UK
    http://www.sterling-power.com/htm/do...pdf/i150gb.pdf
    Definately a pure sine inverter as above and a well recommneded one over here in UK. Inverter cost £80, opus cost me £150. Inverter allows me to take the computer into the house without faffing with wires and I can also use the inverter for other stuff in the car such as my mini fridge. It also monitors the battery as the opus does. Didn't want the ignition to control the computer would rather have a button. Opus holds no advantges for me except noise.
    Didn't think the cigarette lighter thing was a big issue, firstly because its only 150w and the wire can take that load and haven't seen any posts that tell you not to use the cigarette lighter just for the noise issue. Its not an alternator whine because it still does it without the car running and definately not from the computer because it does it when the computers not even connected. Definately coming purely from the inverter. Will try the connection direct to the battery but would prefer not to because of the wiring hassle. I guess a direct connection and making sure the power wires are at a good distance from the speakers and their wires is the best thing.
    LV-670M motherboard
    1.7 mobile pentium
    250gb hard drive
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Well it's not working perfectly, is it? You've got noise in the audio line.
    If you bring it into the house frequently, you should buy an AC-DC 10 amp power supply for the house. Then use the Opus for the car and a connector on the Opus. Make a similar cable for the house DC power supply.
    When you need to bring it into the house, unplug the connector from car and plug it into the cable in the house.
    Want to:
    Mar 2005
    Manchester UK
    Quote Originally Posted by Bugbyte
    Well it's not working perfectly, is it? You've got noise in the audio line..
    I knew someone would come up with that one sooner or later
    I realise everyone loves the opus it just wasn't right for me . Your suggestion sounds like good one however its a little late as I've sold it. Didn't know how to encorporate the "remote" wire the opus needs into a dc connector otherwise I might have tried it at the time. The inverter has made things a lot simpler and if all else fails I'm willing to put up with the noise.
    LV-670M motherboard
    1.7 mobile pentium
    250gb hard drive
    Aug 2005
    Baguio, Philippines
    usually, inverters operate at 60 hertz or 50 hertz. this frequencies are considered audible. that is why most inverters usually produces humming sound. this is often called as noise. in reality, noise can never be eliminated but can be minimize. there are many ways of reducing. one way is by adding a filter circuit. shielding and isolation are other types of methods. this methods is hard to accomplish and cost a lot of time and money.
    if you really want to have a less audible noise, try using a dc to dc converter in your system. they usually operate at a higher frequencies like 60KHz or higher. they produces noise that less audible to human ears.
    if not, try to add a filter circuit to your audio devices.
    **i presumed that ur talking about the noise produced by the speakers.
  1. Computer becomes unresponsive, inverter problem?
    By tsb4k in forum Power Supplies
    Last Post: 10-23-2005, 02:22 PM
  2. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 02:20 PM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 09:04 AM
  4. HELP! Inverter or PSU problem
    By sygad in forum Power Supplies
    Last Post: 07-06-2004, 08:03 AM
  5. PLEASE HELP: noise (hiss, buzz) problem
    By knn444 in forum General Hardware Discussion
    Last Post: 10-17-2003, 07:48 AM
