Results 1 to 10 of 10
Thread: M1-ATX Wiring Diagram -W.I.P.-
    Newbie Chewdog316's Avatar
    Oct 2005
    This is a basic wiring diagram for the M1 PSU any input will be added to it. Please let me know.
    http://www.cardomain.com/ride/775042
    Currently on Navy deployment, Progress haulted.
    |-------*-------| 50% overall completion.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    why are you running audio to your monitor?
    PC Components:
    My work log
    Elsewhere
    The power coming from the M1ATX isn't 12-18v. It's three rails: 12v, 5v and 3.3v in that 20-pin ATX connector.
    I'd also suggest making the VGA and IGN connections more contrasting colors. To someone without a sharp eye, they both are 'yellow'.
    A nitpicky detail, but one that could confuse a n00b or three to the point of posting questions without searching first...
    How about the Wiki?
    Newbie Montanaja's Avatar
    Jul 2005
    Ypsilanti, MI
    Where is the J3 on the M1-ATX?
    Feb 2005
    actually, i have the same question. the J3 isnt labelled on the manual and I found it on the board itself but it's this wierd plug. anyone know what the name of the plug is i need to put into there (that has a molex on the other end). and where i can buy one that'll work for the m1atx
    Variable Bitrate 3g Jester's Avatar
    Nov 2005
    was this ever decided on as a diagram that would have complete functionality? i have found the other diagrams on the faq's but are so complex. im wonding if this simple one will do just as well.
    Newbie HolySdrJR's Avatar
    May 2005
    I tried using a 30A inline fuse and the PS started on fire. I was then told that the M1-ATX 90W PS probably should be using a 10A fuse. Which one is true?
    Color Code:
    PLANNING
    PURCHASING
    PREPARING
    PRESENTING
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    its easy to figure out what size fuse to use... Watts = Volts x Amps ...
    therefore 90w / 12v = 7.5a
    so you actually need a 7.5a fuse to make sure that doesnt burn up.. Unless im missing something obvious..
    can anyone chip in and agree/disagree ??
    Oct 2005
    Miami FL
    from what I understand The M1 comes with a built in 10A fuse. So putting a 10A fuse near the battery sounds good.
    -=VWDASH=-
    Slowly Getting there
    [++++++++++] 100% Planning
    [+++++++++-] 90% Purchasing
    [++++++----] 60% Building
    Nov 2005
    i would say 30 near the battery.literaly next to the bat on the 4 gauge. that way if somethign happens to the wire it grounds..then the fuse blows killing the circuit at a very close dist. to the battery. then a 7.5 fuse maybe right before the PSU. and i dont know why the PSU would burn up? the 10 amp should have blown and the diagram shows you can link it directly to the batt. must be somethign with your system.
  1. Wiring diagram for Opel Corsa
    By wade in forum Car Audio
    Last Post: 10-10-2005, 04:56 AM
  2. My Wiring Diagram
    By mattdisaster in forum Power Supplies
    Last Post: 10-07-2005, 07:01 AM
  3. m1 atx
    By corsab in forum Power Supplies
    Last Post: 08-21-2005, 09:03 PM
  4. Wanted. M1 ATX Lead..
    By CdRsKuLL in forum Classified Archive
    Last Post: 08-12-2005, 10:57 PM
  5. datalux 4x20 red lcd wiring diagram?
    By etrik in forum LCD/Display
    Last Post: 12-07-2001, 04:35 PM
