Results 1 to 7 of 7
Thread: Here's the power requirements for the FV24
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post Here's the power requirements for the FV24
    Just in case anyone needs these, I measured them with my voltmeter. These are all at 100% cpu usage with a celeron 900.
    12V - 0.14A
    5V - 4A
    3.3V - 1.9A
    [ 02-10-2002: Message edited by: Arby ]
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    Which adds up to a whopping 30W, or ~3A on the car's 12V line. (assuming inefficiency of the power supply)
    Apr 2001
    Portland OR
    Post
    Originally posted by Arby:
    <STRONG>
    12V - 0.14A
    5V - 4A
    3.3V - 1.9A
    </STRONG>
    .14 amps on the 12 volts is your cpu fan.
    It is a lot less with a celeron 600 or 566
    Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Mar 2001
    Perth, Australia
    Post
    i wanna get one of these with a via c3 933mhz, no fan and uses less power also, although id still have a couple case fans
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    Have you read up on the performance of the C3?
    their 900 mhz chip performes about the same as a celeron 300.
    go look at benchmarks before you buy one!
    Aug 1999
    Upper Marlboro, MD 20772
    Post
    <STRONG>Have you read up on the performance of the C3?
    go look at benchmarks before you buy one!</STRONG>
    lol....so why did they even call it a 900mhz when it is missing 600mhz... this is too funny
    abcd-1
    Dec 2001
    Paignton, Devon, UK
    Post
    I've been speaking to a guy at via - they are making a new board. Don't know if n e one has heard about it but its a mini itx format board - about 17cm by 17cm and has all the features of the fv24 plus a bit. The bummer is it has a built in cyrix chip, but its very low on power consumption and performs reasonably well - it will watch a dvd or do gps navigation without a problem. What it won't do is play doom 3 at 1024 x 768, but if you don't want your car pc to play games then perhaps this board would be a good one?? The C3 is also cheap and cool - it can (not officially) be run without a heat sink! Think what you will but this isn't a bad processor if you want a car pc plus its cheap!!
    Mediabox Hardware Project
    Current Stage: A complete redesign, although not much happening right now!
    Mediabox Software Project
    Status: Writing Sync Software (still) and playing around with interface
    To do: Far too much!
