Results 1 to 10 of 10
Thread: Q's: Best/Popular Dc-Dc convertor & #Amps for PC?
    Apr 2001
    NJ, USA
    Post Q's: Best/Popular Dc-Dc convertor & #Amps for PC?
    I'm very new to this whole thing, though I've thought about the car PC Mp3player for a while now. I've heard about the Arise DC-DC convertors. Are these considered the best or most popular? Which model should I go with....and branching off this Q, how many amps does a PC with h/d and LCD roughly draw? I'd be using a P90, IBM 20GB, Seiko L4034 LCD, SB-16 soundcard, IBM 10T-T NIC. Thanks.
    P4 2.4GHz, Intel mobo w/onboard sound & video, 128MB memory, 100GB Seagate Momentus laptop drive, Xenarc 700TSV 7" touchscreen, IRman using Girder, 150W Opus dc/dc psu, Alpine CDA-9835 h/u, MBQuart speakers, Infinity 15" sub, MTX amps.
    Aug 1999
    Upper Marlboro, MD 20772
    Cool
    Believe me when i say YES. For proof of it, go take a look at that stuff in my box that that little puppy powers up (including my 6.8" TFT screen).
    For $79, it beats building one not to mention the safety feature built into the psu incase u make a mistake which should NEVER happen. OOH also there is a pic of the psu on my site incase u are wondering how it looks.
    abcd-1
    Jun 2000
    Salt Lake City, UT, USA
    Post
    Save yourself $20 and buy the same power supply here:
    http://www.industrialpcs.com/p_suppl...7004_12_24.htm
    1983 BMW 733i
    Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
    Gathering parts for carplayer v2.0!
    Aug 1999
    Post
    Did u compare the amp rating. Also look at the amps u are getting on the +12v as oppose to the arise one. I strongly think the arise one is better.
    abcd-1
    Mar 2000
    Portland, OR , USA
    Post
    I compared them:
    Peak Input Current:
    Arise ace-865v: 4A
    BPS-7004/12: 4A
    Max Output at +5V:
    Arise: 6A
    BPS: 7A
    Max Output at +12V:
    Arise: 2A
    BPS: 2.5A
    Max Output at -5V:
    Arise: 0.3A
    BPS: 0.3A
    Max Output at -12V:
    Arise: 0.5A
    BPS: 0.3A
    Looks like the BPS compares pretty favorably. And at $20 less, it's a pretty good deal.
    Jun 2000
    Post
    I looked at the specs for both power supplies. They are identical. Both of them output 2.5A at +12v and 7A at +5v. Why would you pay $20 more when they are probably the same power supply?
    Although I will admit that "Arise" is a better name for a power supply than "Open Frame DC-DC Power Supply"
    Maybe that is why they can charge more?
    1983 BMW 733i
    Apr 2001
    NJ, USA
    Post
    Well, there are shoddily made components and then there's quality items. I'm not saying who's using what. They both can be using the same supplier. I'll check them out and ask a few questions. Thanks for the URL.
    Apr 2001
    NJ, USA
    Post
    I checked out the Arise's specs and they list the ACE865V min input is 8V and the Industrial PC's model is 10V. Two volts might not make that big a difference, but all in all the two are very close in specs. Since more guys here use the Arise I think I'll go with them.
    Now the next question is do they already have the connectors installed so I can just pop it onto my P90 m/b or is that something else I must order? Thanks guys.
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    I'd pick the Arise unit simply becasue it has a lower minimum voltage. The voltage can easily drop to 8V when cranking a car on a cold winter morning.
    Apr 2001
    Portland OR
    Post
    How many amps does a PC with h/d and LCD roughly draw?
    Well in my setup, I draw about 3.0 amps off the 12 volt feed from the car. That is about 35 watts.
    First, the power conversion on my power supplie is about 85 percent efficient. That leaves 30 watts. Most of it is the + 5V supply, say 24 watts (4.5 amps) and the rest is the 12 volt line say 6 watts (0.5 Amps) The minus 12 line only uses a few milliamps, (under 50).
    Those three are the only power lines I use.
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
