Results 1 to 10 of 15
Thread: newbe and almost finish
    Jan 2002
    Puerto Rico
    Question newbe and almost finish
    hi i am new at this can some one post a diagram of the electrical wireing for a carputer i have the power inverter and the PSU do i need something else?
    this is done and my carputer is finish!!!!!
    i am sorry i bet there is a thred already about this but i didnt find it
    [ 02-12-2002: Message edited by: kris3 ]
    carputer:
    P2- 266 mmx
    94 ram
    WD 9 Gigas
    ATI AIW
    on SUBARU IMPREZA 2000
    Banned
    Jun 2001
    Adelaide, Australia
    Post
    I personally wouldn't consider using an inverter as being finished, as this is a cheats way, but thats just my opinion,.. Do you have any pics???
    2 week temp ban (spam and complaining about deleted posts)
    register another account and you're gone for good.
    Jan 2002
    Puerto Rico
    Post
    soon i will post pics when finish i just tested the carputer and worked great. now i need some case ajustments and i think is done. but if any one has a sugestion, always welcome.
    carputer:
    P2- 266 mmx
    94 ram
    WD 9 Gigas
    ATI AIW
    Jan 2001
    Adelaide, SA, Australia
    Post
    Hey kris3, congrats on your system.
    Don't listen to THEMP3KID, using an inverter is fine for 70% of the people out there.
    To wire up your inverter, it would be best to run a wire directly from your battery to power it. Then you could either set up a relay off the acc line of your car (so the inverter turns on and off with the accessories line of your car) or mount a switch in the line, to manually turn the inverter on and off.
    Both setups have there pros and cons, its just down to your personal prefference
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
    Jan 2002
    Puerto Rico
    Post
    thankz i just did exactly the same u told and is working great!!! now some cosmetic adjustmen
    carputer:
    P2- 266 mmx
    94 ram
    WD 9 Gigas
    ATI AIW
    Jan 2002
    Puerto Rico
    carputer is done just some problems with the lighter plug that i wired to the trunk. Seems like it the fem of the plug is a bit larger than the inverter plug and it loose and turns off my pc when the car bounce. I was thinking to make a solering point at the tip of the plug so it wont get loose.
    Aug 1999
    Upper Marlboro, MD 20772
    Y do you guys think mp3Kid is wrong. take it from me and prolly from him. Sure your inverter works fine now, i guarantee you that down the road, you will start to experience strange things... it might now happen right away, but once the signs start showing up, it will **** u off
    abcd-1
    Jan 2002
    Puerto Rico
    what kind of things could happen??
    tell me, tell me !!!
    carputer:
    P2- 266 mmx
    94 ram
    WD 9 Gigas
    ATI AIW
    FLAC Mastero's Avatar
    Aug 2001
    India
    hey kris why do u want to play with AC power in a car .. after all you just require DC power unless ur planing to put a microwave or other home appliance in your car ..??
    Think Ac current in your car just a case of badluck and the AC current runs through your cars body .......! BOOm ! you will see 4th of July a bit too earlier..
    Advice inverter is NOT good!....
    Mastero
    Jan 2002
    Puerto Rico
    ok then what options do i have remember i am a newbe...
    carputer:
    P2- 266 mmx
    94 ram
    WD 9 Gigas
    ATI AIW
