Results 1 to 4 of 4
Thread: What psu do i choose?
    Mar 2005
    UK
    I will run less than 150watt.. as i got temp psu running in my computer atm!
    I want it to auto start up/shutdown.
    Please help!
    Variable Bitrate StrataG's Avatar
    Aug 2005
    New York
    Give us some more specs as to what type of processor, hard drives (physical size and speed), graphics card, usb devices, optical drives, etc.
    It's not as simple as knowing how many watts your system uses. There are individual lines on a power supply, 3.3V, 5V, and 12V being most important. Unfortunately just because your temporary PSU is running right now, doesn't mean you aren't pushing it over it's limit and asking for a failure. Depending on your needs, you may want to go with an Opus 150W or a M1-ATX paired with a 1260 or 1290 to power your drives and USB devices. If you give us some more details it may turn out you only need an m1-atx.
    Mar 2005
    UK
    AMD Athlon XP 2000+
    700 odd mb DDR RAM
    60 GB 7200rpm Maxtor Harddrive
    10/100 Local Area Network
    nVidia 128mb Geforce TI 200
    DVD-ROM Drive
    Abit AT7-MAX2 Motherboard
    Aug 2005
    New York
    Quote Originally Posted by World705
    AMD Athlon XP 2000+
    700 odd mb DDR RAM
    DVD-ROM Drive
    I would suggest zootjeff's 220 watt PSU. You CPU requires 5A+ alone on the 12V rail. Not sure if you are using a 3.5" or 2.5" drive, but assuming 3.5" which will require another 2A. DVD drive internal will also require more juice on the 12V rail, as well as fans. You also need some room for your monitor if you will power it off the PSU. If those are all desktop components, the Opus 150 watt will not be enough. You could get the Opus and get a Carnetix 1260 or 1290 to power your drives/screen. I think zootjeff's PSU is your cheapest solution.
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 07:45 AM
  2. Does CNX 140W PSU support standby/hibernate as OPUS 150W PSU does?
    By baboojoon in forum General Hardware Discussion
    Last Post: 07-07-2005, 11:27 PM
  3. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 06:25 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 01:07 AM
