Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: System Restarts whenever I start my car
  1. #21
    Apr 2001
    Portland OR
    Post
    Originally posted by jjohnson:
    <STRONG>
    I've been using a custom-built ATX DC-DC PSU for about 4 months now and have never had any problems. The computer never reboots or hangs when I start the car. </STRONG>
    jjohnson,
    I'm very interested in what components you used to make your supply. Would you mind listing the IC's that you used to make your supply?
    Also, did you take the path of free samples or go through someone like Digikey?
    Thanks,
    Jeff_
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
  2. #22
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    Originally posted by Jeff Mucha:
    My car has no problem starting. It starts
    I didn't say it did.
    I don't remember ever saying that my cars voltage was down at 8 volts during starting. I said that it could happen if the internal resistance of the battery got very big.
    I didn't say it did. I just said that "if it does, then....".
    Also, My car is not fuel injected. It is my guess that the folks at Honda found a good way to deal with batteries
    You have a Honda that's not fuel injected? Is is modified to use a carb? Why? Or is it just really old?
    What is so wrong with using a diode and a capacitor if it works and solves the problem?
    That's just it, it doesn't solve the problem. It just masks the symptoms. Solving the problem would involve fitting a larger battery, larger alternator, or both.
  3. #23
    Apr 2001
    Portland OR
    Post
    Originally posted by Aaron Cake:
    <STRONG>That's just it, it doesn't solve the problem. It just masks the symptoms. Solving the problem would involve fitting a larger battery, larger alternator, or both.</STRONG>
    Some guy who is overweight found that eating celery when he is hungry helps him lose weight.
    The correct solution is to get a lyposuction, staple the stomach, and go on Jenny Craig because we all know eating celery just masks the fact that if he eats normal he will get fat again.
    If you think that 3 extra amps of draw on a cars electrical system necessitates a new alternator and battery, thats ok for you, but I don't have that kind of money :-(
    www.mpegbox.com
  4. #24
    Jan 2000
    Cool
    That is a solution.
    While this is a solution, it is not necessarily the best solution.
    Ugh, I don't even remember what this topic was about anymore...I just took a quick look back and it appears the original problem was a machine rebooting when the car was started. The solution is to replace a weak/undersized battery, install better cabling, or both depending on the need. I didn't say that an extra 3A would require an alternator upgrade. It was just added as an example. Perhaps I should be clearer next time.
  5. #25
    Moe
    Moe is offline
    Jun 2001
    Post
    Its very simple: if you have a newer higher quality battery simply hook a direct line. if your battery is old then add a simple filter with a schotty diode in series with the battery and a .05 or up farad capacitor in parrallel with your load. the size of the cap dependes on the impedence or equivalent resistance of your load.
