Just a photo of HT connected to the DSATX, displaying the diagnostic data on-screen.
The following chart info is taken from zootjeff's site, and will aid in interpreting the data from my photo..
Serial Port Diagnostic data takes this form (Data will flow out every 200ms):
A : B : C : D : E : F : G : H : I : K
A: Temperature in Degrees C
B: Input voltage at VIN
C: 12 Volt Rail Output
D: 5 Volt Rail Output
E: 3.3 Volt Rail Output
F: Low Voltage Threshold (P2 Adjusts this)
G: Number of Seconds for main Shutdown Timer (P1 Adjusts this)
H: Y/N Good/Bad(Vin Voltage Good, Acc Pin High, Temp Good)
I: State of SDC : (0: off, 1:Pulse, 2: Running, 3: Cnt Down, 4: Shut Down)
K: Count value for Shutdown Counter (seconds)
LinkBack URL
About LinkBacks
because the manufacturer of the brainstem serial adapter (acroname.com) provides the schematic on their website :P
