Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Psu
    Constant Bitrate racerx3165's Avatar
    Sep 2005
    McConnell AFB Wichita Ks.
    Psu
    Ok kinda a stupid noob question, i understand that a computer operates on 12v 5v and 3v so why can you not just use the 12v strait from the car battery then get or build a 12-5v converter and a 12-3v converter? i know that smaller converters are simple to build and can pretty much be pieced together from Radio Shack for like 3-5$ I do understand that thoose are way to small to power PC components but how hard would it be to get Larger pieces and put them together. So what idea/thought am i not getting. Just so you know why im thinking so outta the box is that i am an USAF Electrician, well right now im an Electrical contigency instructor and i have attended many hundreds-thousands of hours about Electronic principals digital and microprocessing classes so im thinking maybe i can do this So how wrong am i...
    Cars
    1994 Mustang GT Punch 240.4 2 12" Kicker Comp SOLD :(
    2006 Suzuki Aerio Sx Kicker KX 650.4 RE 10
    2003 Eddie Bauer Expedition DVD - Navigation Package Traded in for 2008 XL-7 Limited
    Car PC
    Planning
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    You will never get enough current from the convertors, plus it wont withstand engine cranking
    and so much more....
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
    Mar 2004
    Bristol
    Quote Originally Posted by racerx3165
    very!
    This is gonna sound very harsh but do they seriously let you loose on $million planes?
    Mind, you i have seen what goes on in the RAF. No wonder an aero engineers life is not so simple - he have to design for mechanics doing more damage than the enemy. Did anyone see the pictures from when a techie made a home-made pressure regulator? he didnt notice it go round once and continued to pressurise the aircraft until the thing blew up on the runway. The cargo door nearly killed somone!
    Basically it is not that simple. I wish it was.
    You need to regulate the 12V or you will fry the PC. Most regulators drop a couple of volts so you need to step up the input. Then you need to provide enough step up for crank when the voltage can drop below 9V input.
    You need to perform this step up to provide a lot of power on the 12V rail which is no easy task. You also need to have good robust circuits due to the harsh car electrical system.
    Then you need to add an SDC so you begin to realise why dc-dc solutions are not cheap.
    Mar 2004
    Bristol
    erm try:"about as wrong as letting Garry Glitter babysit for you while you go on holiday for 2 weeks!"
    just thought of that one! I bet Chris31 will like it - you could replace 'Garry glitter' with 'Chris31'
    Sep 2005
    I mainly deal with the High Voltage side of the house from 250,000 on down. Basically i am a Lineman "well AF Lineman" http://usmilitary.about.com/od/airfo...afjob3e0x1.htm
    Cars
    Car PC
    Planning
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    The car battery is not regulated. In other words , the voltage can go up to 15 volts and down to 6 volts or more. Also there is spikes(voltages goes VERY high or low).
    To get that "12" volts to 12 volts , you need to regulate it (with a regulator).
    Registered User
    May 2003
    I knew scouse will come and abuse you.
    Mar 2004
    Bristol
    Quote Originally Posted by Chris31
    thats cos you pointed it out to me cos you wanted to see what i would write.
    Sep 2005
    I just figured if you can make a 120V-12V PSU at 500W+ there has to be a easy way to make a 9-18V-12V DC DC PSU around 300W
    Cars
    Car PC
    Planning
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. Does CNX 140W PSU support standby/hibernate as OPUS 150W PSU does?
    By baboojoon in forum General Hardware Discussion
    Last Post: 07-08-2005, 12:27 AM
  3. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
