Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: Could, Would, Should this work??
    Jul 2001
    Lightbulb Could, Would, Should this work??
    Well, is I use the 6volt-12volt voltage doubler thing on Aarons website, and change the zener diode to a 15volt or so, could I use this for the 12volt rail for my player, using a 7812 regulatoer as well?? And then use a 7805 and a transistor for the 5volt rail?
    The power supply would run on between about 7 and 16 volts...
    would this work???
    [ 07-18-2001: Message edited by: THE_SKINNY_MP3_KID ]
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    The circuit will not provide enough power to run the 12V rail in a standard PC. You're looking at about 2A or more required. Significantly more is required at startup.
    Jul 2001
    Talking
    Not so Aaron, my carputer only draws about 1amp max on the 12volt line, and it is normally below 500ma....
    so, it would work??
    Jan 2000
    Post
    Originally posted by THE_SKINNY_MP3_KID:
    <STRONG>Not so Aaron, my carputer only draws about 1amp max on the 12volt line, and it is normally below 500ma....
    so, it would work??
    </STRONG>
    Sorry, but I can't believe that. It may idle at 1A, but startup surges will be much higher. You can try the circuit, but I can't guarantee that it will work.
    Jul 2001
    Post
    I will try it.....
    My HD draws 280ma 12v MAX
    My Mobo draws I don't know....
    Three cards??? Dunno either....
    Jul 2001
    Post
    Yeah, I forgot, 4 fans... not much either....
    Jan 2000
    Cool
    Sigh. I'm guessing that your HD draws about 10A for a split second to start up. 280mA is the running idle current. The motherboard pulls probably 2A or more on the 12V rail, and around 8A at startup. It won't work. You've been warned three times, so don't complain to me when you spend $25 and several hours assembly for nothing.
    For the amount of money and time you spend on this, you are just better off buying an Arise DC-DC converte for $79. It's usually cheaper to buy than it is to build.
    Aug 1999
    Upper Marlboro, MD 20772
    Cool
    lol...
    Very true....I keep telling ppl this and they dont want to cough up $79. I guess they WILL never learn.
    abcd-1
    May 2001
    Australia
    Post
    I think using linear regulators for a PSU is a lost cause. They can't handle the current and generate too much heat. Aaron is right about the large switch on surge current drawn by hard disks. If you don't believe him(or me) look on the seagate website. They have datasheets for their drives which show the current drawn over time as the hard disk spins up. I can't use some full sized hard drives(particularly new models with high rotational speeds) in my player because my DC-DC converter is only 40 watts(I have a laptop hard disk).
    I noticed you live in Aus(as do I) which makes sourcing things from OS an expensive exercise. A good source of DC-DC converters is old 286 laptops(soured mine from one)... and they can be had for less than $79(US or $160AU + Postage + Insurance) if you can find one at the markets. :P
    Jan 2001
    Adelaide, SA, Australia
    Post
    Is that true? Do laptop psu's output all the right voltages? and they can run on 14-8 volts? dont need steady 12v?
    would one of these be enough to power a P133, network, soundcard, video card, hdd, no cdrom etc.??
    Cheers!
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
