Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: found plans for 86W ATX DC-DC
    moahdib's Avatar
    Jul 2000
    Post found plans for 86W ATX DC-DC
    This looks like a good PSU the page is in spanish or something tho hehe
    here is the guy's car PC webpage: http://dmc.freeweb.supereva.it/
    there's another version of it... http://mysite.ciaoweb.it/casahardware/car_mp3.htm
    Since I am no good at building these things i just thought I'd share my finding.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Apr 2001
    Here, There, Everywhere
    Post
    good find moahdib....!
    Project - GAME OVER :(
    Jan 2001
    Post
    Probably in Italian... anyway goodfind
    Jan 2001
    Post
    yep.. it's italian. babelfish does a fair job of translating
    moahdib's Avatar
    Jul 2000
    Post
    nevertheless...whatever language it may be that's a tight little PSU =)
    Can anyuone figure out what the input range is ?? 8-14V perhaps?
    My TL CarPC ver2
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    Post
    I Tracked down the datasheet of the MC78TI12CT which is used in this schematic to produce the +12v output.
    "The input-voltage must remain typically 2.2v above the output voltage even during the low point on the input ripple voltage..."
    So this thing must have 14v to run properly.
    Damn... sounded too good to be true
    Greetz
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
    moahdib's Avatar
    Jul 2000
    Post
    Hmm can't you just add another type of voltage regulator?
    One that can accept from 8-14V and output 12V 3A??
    My TL CarPC ver2
    Jan 2001
    The Netherlands
    Post
    Well...
    Someone said that the LM2587-12T from national Could supply 12v@5a but that there was some limitation on the Coil so that it would produce 1-2a@12v.
    Maybe another Coil ???
    But when you're going to use the LM2587-12T, you're almost going to build the sproggy-supply. The design mentioned by you also used the 'popular' MAX788 & MAX787
    This design is very similar.. It's only supplying more current on the 12v rail, but therefore it needs an input off at least 14v.
    Damn....
    Why is it so hard to find a decent component that produces like 12v@5a with Vin = 8-16 Anyone ??
    Greetz.
    Aug 1999
    Upper Marlboro, MD 20772
    Cool
    Come on ppl....someone really need to produce a good/real DC-DC atx psu. I have my next altimate project overloading my brain cells, i need to ofload some of these thoughts and logic hurry damnit
    abcd-1
    Jan 2001
    The Netherlands
    Post
    just checked the lm2587-12t datasheet.
    It states that it CAN supply 5a
    but that's only with the lower (output) voltages
    At 12v you can get 1.2A at best
    Charles is absolutely right we all need to combine our forces and thought about this 12v issue.
    It's pretty easy to produce the 5v and 3.3v voltages, with some components we could easily produce 10a, 15a or maybe even more A's (use some more of the maxim-chips)
    But why are we still having this problem with the 12v rail ???
    I suppose the Keypower & Arise power-supplies will produce more than enough current @ 12v
    Isn't there a way that we can 'adapt' some of this ??? (in other words... could someone open the PSU to find out how they handled the 12v.)
    I'm absolutely no electronics-wizard, but I do find it a bit hard to believe that there isn't some way that we can produce 12v @ 5a (at least!)
    F^(#ing 12 volt issue !!!!!
    Greetz
